[mapserver-users] Projection or Data Problem?
Moen, Paul T. pmoen at nd.gov
Thu Mar 5 14:24:57 EST 2009
If I get what you are saying, I should set up another Mapserver as a WMS
server that accesses the WMS from BLM, then, connect to my WMS server with
the original mapfile?
Doesn¹t Mapserver already take the temporary image from the WMS that was
delivered in epsg:4326 and reproject it to my mapfiles projection,
epsg:2266, then add the other layers of my mapfile before delivering the
final image?
This certainly works for the other WMS layer, OFlood Data Availability¹ that
is in my mapfile.  That layer is delivered by the WMS in epsg:4269 and lines
up perfect when the mapfile¹s main projection is set to ³init=epsg:2266².
Thanks for helping,
On 3/5/09 1:06 PM, "Gregor at HostGIS" <gregor at hostgis.com> wrote:
> Moen, Paul T. wrote:
>> Can anyone get this WMS layer to reproject to a projected coordinate
>> system like epsg:2266?
> Add to your WEB block, this. You can then make requests to your
> mapfile-as-WMS in the given SRS.
>    "wms_srs"  "EPSG:2266"
> This does mean fetching the raster from them as 4326, then reprojecting
> it to 2266, so it may not look so great. But if they're not offering it
> in 2266, that's what you hafta do.
> Gregor Mosheh / Greg Allensworth    BS, A+, Network+, Security+, Server+
> System Administrator, Lead Programmer
> HostGIS development & hosting services, http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
>   only if you can restore." - AMANDA
