[mapserver-users] msProcessProjection(): Projection library
error. no system list, errno: 2
kapilmanoj
kmanoj-pg7 at iiitmk.ac.in
Fri Mar 6 05:38:33 EST 2009
hi all,
i have done a blunder mistake in the Projection tag of the above mapfile, i
have written espg instead of epsg , that was the root cause of the above
error has been thrown.
just forgive me.......
Thanks
kapilmanoj
kapilmanoj wrote:
> Dear users,
> I am using fedora 9 with mapserver 5.0.3 , i installed mapserver by using
> YUM install command through command prompt. Now I am trying to use the
> 'projection' tag in a map file, but it is not working. I installed
> proj-4.6.0 also as like the above same way. However, when using the
> 'projection' tag, it gets
> * msProcessProjection(): Projection library error. no system list, errno:
> 2
> This is my map file for your perusal,
> Map
> IMAGETYPE PNG
> NAME "Gods own country"
> SIZE 800 500
> IMAGECOLOR 256 255 255
> EXTENT 74.906173 8.249055 77.434938 12.791817 #geographic
> SHAPEPATH "/var/www/html/mapfiles/sampletest/data"
> FONTSET "/var/www/html/mapfiles/sampletest/fonts/fonts.list"
> SYMBOLSET "/var/www/html/mapfiles/sampletest/symbols/symbols35.sym"
> PROJECTION
> "init=espg:4326"
> END
> LAYER
> NAME kerala
> TYPE POLYGON
> STATUS OFF
> DATA parl_04
> PROJECTION
> "init=epsg:4326"
> END
> CLASSITEM "PARTY"
> CLASS
> NAME "Greenary Land"
> EXPRESSION 'CPM'
> STYLE
> COLOR 256 256 255
> OUTLINECOLOR 256 256 256
> END
> END
> #second class starts
> CLASS
> NAME 'CPI'
> EXPRESSION 'CPI'
> STYLE
> COLOR 198 198 255
> END
> END
> END #end of first layer
> LAYER # States label layer begins here
> NAME states_label
> DATA parl_04
> STATUS OFF
> TYPE ANNOTATION
> PROJECTION
> "init=epsg:4326"
> END
> CLASSITEM "PARTY"
> LABELITEM "NAME"
> CLASS
> EXPRESSION 'CPM'
> STYLE
> COLOR -1 -1 -1
> END
> LABEL
> COLOR 132 31 31
> SHADOWCOLOR 218 218 218
> SHADOWSIZE 2 2
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 12
> ANTIALIAS TRUE
> POSITION AUTO
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END # end of class
> CLASS
> EXPRESSION 'CPI'
> STYLE
> COLOR -1 -1 -1
> END
> LABEL
> COLOR 132 31 31
> SHADOWSIZE 2 2
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 12
> ANTIALIAS TRUE
> POSITION AUTO
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END # end of class
> END # States label layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END #map ends here
> The interesting thing to look out about this projection is when i add the
> projection tag both in the map object and layer object , its showing the
> above error
> * mProcessProjection(): Projection library error. no system list, errno: 2
> but when i remove the projection tag from the map object leaving the
> project
> tag as it is in the layer object (not remove) its working fine, projecting
> the map without making any problem in the browser
> The apache error logs don't show anything interesting, but it still
> returns
> this:
> 2
> when i add the projection tag in the map object.
> what could be a problem? somebody please help me out...
> help/tips will be appreciated.
> Thanks,
> kapilmanoj.
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/msProcessProjection%28%29%3A-Projection-library-error.-no-system-list%2C-errno%3A-2-tp2428209p2434929.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
