[mapserver-users] msWMSDispatch(): WMS server error. Incomplete
WMS request: VERSION parameter missing
Cassiel
raffaele.morelli at gmail.com
Sun Mar 8 08:03:30 EDT 2009
WEB
TEMPLATE "map.html"
IMAGEPATH "/var/www/cem/tmp/ms_tmp/"
IMAGEURL "/tmp/ms_tmp/"
LOG "/var/www/cem/tmp/mapserver.log"
METADATA
#"MAPFILE_ENCODING" "ISO-8859-1"
"wms_title" "WMS CEN-RF"
"wms_onlineresource" "
http://193.206.192.55/cgi-bin/rf_mapserv?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
"wms_srs" "EPSG:32632
EPSG:4269 EPSG:4326"
END # Metadata
END # Web
Here it is one of the two wms_onlineresource links
I am using two apache environment variable to point to rf_mapserv or
elf_mapserv (they are symlinks to mapserv..) in order to return two
different mapfile as explained in the mapserver doc.
regards
raffaele
2009/3/7 paalkr <pal.kristensen at statkart.no>
> Hi!
> Have you set the ows_onlineresource parameter in the WEB element in the
> mapfile?
> Regards,
> Pål Kristensen
> Cassiel wrote:
> > I must say that this issue arised when I moved the website to another
> > webserver... same OS, debian lenny, but different arch 32bit -> amd64.
> > The 32 bit machine was hosting only one website.
> > Te new amd64 webserver hosts two sites (name based virtual host) so the
> > wms
> > request is served by a virtual host (Apache 2.2), same ip address for two
> > dns. Could it be a dns related issue? does mapserv bin complains about
> > virtual hosts?
> > Since I switched from the old machine to the new I can't get no wms layer
> > with QGis even with the version request variable (it was there from the
> > start).
> > This is my WMS link:
> > www.catastocen.apat.it is the dns name.
> > If you substitute the numeric address with the dns one mapserver returns
> a
> > binary file...
> > thanks for responding
> > regards
> > raffaele
> > 2009/3/6 paalkr <pal.kristensen at statkart.no>
> >> Hi!
> >> This is fixed in ticket #2528, and applied in MapServer 5.2.0. Version
> is
> >> a
> >> optional parameter in the GetCapabilities request, as described in the
> >> WMS
> >> 1.1.1 specification, chapter 7.1.2, table 4. In earlier version of
> >> MapServer
> >> the version parameter was treated as mandatory.
> >> You can resolve your issue in to different ways:
> >> 1) Add a &version=1.1.1 to your service URL in Qgis
> >> 2) Upgrade to MapServer 5.2.0 or later.
> >> Regards,
> >> Pål Kristensen
> >> Cassiel wrote:
> >> > Hi you all,
> >> > I am getting this error using Mapserver 5.0.3 on debian lenny when
> >> > querying
> >> > for WMS available layers on Qgis.
> >> > Querying with iceweasel on debian works , i.e. the proper xml file is
> >> > returned, while it does not on Mac OS X.
> >> > Any hints?
> >> > Regards
> >> > Raffaele
> >> > _______________________________________________
> >> > mapserver-users mailing list
> >> > mapserver-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> View this message in context:
> http://n2.nabble.com/msWMSDispatch%28%29%3A-WMS-server-error.-Incomplete-WMS-request%3A-VERSION-parameter-missing-tp2435750p2436095.html
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> http://n2.nabble.com/msWMSDispatch%28%29%3A-WMS-server-error.-Incomplete-WMS-request%3A-VERSION-parameter-missing-tp2435750p2442129.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090308/37e78736/attachment.html
