[mapserver-users] PHP - configuring error with mapserver- 5.0.3
kapil manoj
manojkapil06 at gmail.com
Tue Mar 10 06:30:20 EDT 2009
hi all,
i am a new user , i am using mapserver 5.0.3 on fedora 9... i am struggling
in installation as well as configuration part of mapserver in my box. well,
come to the point i am trying to configure php with mapserver , but
configuration error occured while configuring. I have installed php-5.2.6
through *yum install* in my system.
The following is the configuration error
ug 458 or Apache bug 22030).
Compiling with fast MS_NINT
checking compiler warnings... basic
configure: checking whether we should enable debug features...
Enabling debug features: -g in CFLAGS.
*configure: checking for PHP/MapScript module options...*
*configure: error: Missing or invalid PHP source directory in
--with-php=DIR.*
>From the error message it is clearly evident that i gave invalid source
directory, but the following are the php source directories found in my
system
/etc/php.d
/etc/php.ini
/etc/httpd/conf.d/php.conf
/etc/php.d/dbase.ini
/etc/php.d/error_log
/etc/php.d/gd.ini
/etc/php.d/json.ini
/etc/php.d/mapserver.ini
/etc/php.d/mysql.ini
/etc/php.d/mysqli.ini
/etc/php.d/pdo.ini
/etc/php.d/pdo_mysql.ini
/etc/php.d/pdo_pgsql.ini
/etc/php.d/pdo_sqlite.ini
/etc/php.d/pgsql.ini
/etc/php.d/zip.ini
*/usr/bin/php*
/usr/bin/php-cgi
*/usr/lib/php*
/usr/lib/httpd/modules/libphp5.so
/usr/lib/php/modules
/usr/lib/php/pear
/usr/lib/php/modules/dbase.so
/usr/lib/php/modules/gd.so
/usr/lib/php/modules/json.so
/usr/lib/php/modules/mysql.so
/usr/lib/php/modules/mysqli.so
/usr/lib/php/modules/pdo.so
/usr/lib/php/modules/pdo_mysql.so
/usr/lib/php/modules/pdo_pgsql.so
/usr/lib/php/modules/pdo_sqlite.so
/usr/lib/php/modules/pgsql.so
/usr/lib/php/modules/php_mapscript.so
/usr/lib/php/modules/phpcups.so
/usr/lib/php/modules/zip.so
*/usr/share/php*
/usr/share/doc/php-cli-5.2.6
/usr/share/doc/php-common-5.2.6
/usr/share/doc/php-mapserver-5.0.3
/usr/share/doc/php-cli-5.2.6/README
/usr/share/doc/php-cli-5.2.6/README.FastCGI
/usr/share/doc/php-common-5.2.6/CODING_STANDARDS
/usr/share/doc/php-common-5.2.6/CREDITS
/usr/share/doc/php-common-5.2.6/EXTENSIONS
/usr/share/doc/php-common-5.2.6/INSTALL
/usr/share/doc/php-common-5.2.6/LICENSE
/usr/share/doc/php-common-5.2.6/NEWS
/usr/share/doc/php-common-5.2.6/README.EXTENSIONS
/usr/share/doc/php-common-5.2.6/README.EXT_SKEL
/usr/share/doc/php-common-5.2.6/README.PARAMETER_PARSING_API
/usr/share/doc/php-common-5.2.6/README.PHP4-TO-PHP5-THIN-CHANGES
/usr/share/doc/php-common-5.2.6/README.SELF-CONTAINED-EXTENSIONS
/usr/share/doc/php-common-5.2.6/README.STREAMS
/usr/share/doc/php-common-5.2.6/README.SUBMITTING_PATCH
/usr/share/doc/php-common-5.2.6/README.TESTING
/usr/share/doc/php-common-5.2.6/README.TESTING2
/usr/share/doc/php-common-5.2.6/README.UNIX-BUILD-SYSTEM
/usr/share/doc/php-common-5.2.6/README.UPDATE_5_2
/usr/share/doc/php-common-5.2.6/README.WIN32-BUILD-SYSTEM
/usr/share/doc/php-common-5.2.6/README.input_filter
/usr/share/doc/php-common-5.2.6/TSRM_LICENSE
/usr/share/doc/php-common-5.2.6/ZEND_CHANGES
/usr/share/doc/php-common-5.2.6/ZEND_LICENSE
/usr/share/doc/php-common-5.2.6/gd_README
/usr/share/doc/php-common-5.2.6/regex_COPYRIGHT
*/var/lib/php*
/var/lib/php/session
I tested with all the source directories that i have in my system, but the
error still remains. i have installed php through YUM INSTALL way , that is
a precompiled binaries not an source package.. May be that could be a
reason to cause this error.. i am not sure....
so what could be a problem .... please somebody help me...
regards
zizu
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090310/c4e2b011/attachment-0001.html
