[mapserver-users] RE: 5.4 beta 3 - GetFeatureInfo /FILTER problems
Jennifer Shanks
shanksje at yahoo.com
Thu Mar 12 16:33:17 EDT 2009
Hello Everyone,
Gregor at HostGIS came to the rescue on this one. He did some testing and suggested adding parenthesis to my filter statement. So if I do the following my request returns the correct response:
FILTER "(access_cod = 'Restricted Access' or access_cod = 'Open Access')"
Thanks,
Jennifer
----- Forwarded Message ----
To: mapserver-users at lists.osgeo.org
Sent: Thursday, March 12, 2009 1:55:07 PM
Subject: 5.4 beta 3 - GetFeatureInfo /FILTER problems
Hello,
We installed 5.4 beta 3 last night to take advantage of the new labeling options. The new labels are great!
I've noticed a problem with my GetFeatureInfo requests. If there is a data FILTER on the layer, the request returns the wrong feature (always the same feature, no matter which location I select in CA. If I comment out the FILTER, the request returns the correct result. Below is an example of my layer.
And a request looks like this:
http://www.parkinfo.org/cgi-bin/mapserv?map=wms_parkinfo_4326.map&SERVICE=WMS&SRS=EPSG:4326&VERSION=1.1.1&REQUEST=GetFeatureInfo&X=596&Y=636&QUERY_LAYERS=Parks_GetInfo&LAYERS=Parks_GetInfo&INFO_FORMAT=text/html&BBOX=-128.4521484375,36.13787471840729,-116.65283203124999,44.68427737181224&WIDTH=1060&HEIGHT=768&FORMAT=image/png&STYLES=
If I use this same request, I get different results depending on whether the filter is turned on or off.
Any suggestions as to how I can fix this would be much appreciated.
Thanks,
Jennifer
LAYER
NAME "Parks_GetInfo"
STATUS OFF
METADATA
"wms_title" "Parks_GetInfo"
"GROUP" "Polygon"
"LAYER" "Parks_GetInfo"
END #metadata
TYPE POLYGON
TEMPLATE "parkinfo_template.html"
TRANSPARENCY 100
CONNECTION "user=mapserver password=******* dbname=parkinfo_current host=localhost"
CONNECTIONTYPE POSTGIS
DATA "the_geom_gcs from statewide_osdb_notsvector as foo using unique gid using srid=4326"
#FILTER "access_cod = 'Restricted Access' or access_cod = 'Open Access'"
CLASS
OUTLINECOLOR 255 0 0
END #class
TOLERANCE 5
PROJECTION
"init=epsg:4326"
END
END # Layer
