[mapserver-users] NQuery problem
Subha Ramakrishnan subha at gslab.com
Fri Mar 13 02:44:03 EDT 2009
Hi
Here's how the layer looks in my mapfile:
layer
  name abc
  connectiontype postgis
  connection "user= user dbname=xyz host=localhost"
  type point
  tolerance 20
    group world
    dump true
    METADATA
       "wfs_title" "Factbook Metadata"
       "gml_include_items" "all"
       "wms_feature_info_mime_type" "text/html"
    END
    template "template.html"
    projection
      "init=epsg:4326"
    end
    transparency 65
    status on
  data "topology from tablename using unique id using SRID = -1"
  classitem "veg_class"
        class
                name "AGRICULTURE"
                expression "AGRICULTURE"
                style
                        symbol 'custom_icon'
                        size 20
                        color 179 189 209
                        outlinecolor 000 000 000
                end
        end
end
Status is on and template is defined.
Am i missing something else?
Thanks a lot for the help.
Subha
Steve Lime wrote:
> For a layer to be queryable you have to:
>   1 - either set Status DEFAULT, or explicitly turn it on (e.g. layer=abc)
>   2 - define the layer TEMPLATE property
> Are those true?
> Steve
>>>> Subha Ramakrishnan <subha at gslab.com> 03/13/09 12:38 AM >>>
> Hi,
> I am also facing a similar problem. It doesn't throw an error but it
> doesn't give me a result either.
> My url looks like this :
> http://localhost/cgi-bin/mapserv?MAP=abc.map&MODE=nquery&LAYERS=abc&imgext=8920506.9477+3496535.4213+8954750.736418456+3530779.2100573704&imgbox=657+209+686+239&imgxy=670+230
> The extent given here is within  the map extent.
> Can you please tell me if there's some mistake here?
> Thanks a lot.
> Subha
> Steve Lime wrote:
>> Nquery doesn't require qstring validation. What does your URL look like?
>> Steve
>>>>> Rui Gomes <ruijgomes at gmail.com> 03/12/09 9:42 PM >>>
>> I try to use the nquery function and i recived the follow error message:
>> mapserv(): Web application error. Metadata qstring_validation_pattern
>> is not set.
>> To avoid this i insert in the mapfile the follow lines inr the layer i
>> want to query:
>> METADATA
>>           qstring_validation_pattern '.'
>> END
>> What this lines means. Why i have to put it?
>> Thanks
