[mapserver-users] NQuery problem
Subha Ramakrishnan subha at gslab.com
Fri Mar 13 11:12:36 EDT 2009
Hi David,
Thanks a lot for the reply.
It would be great if you can give me an example url.
Thanks & regards,
Subha
Fawcett, David wrote:
> Subha,
> In taking a quick look at your layer, I think that you have a problem
> with your data statement.  I am quite sure that if you want to use an
> attribute(column) from your data layer for classification or query
> results, you need to explicitly include the name of that column in the
> select query that is in your data statement.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Subha
> Ramakrishnan
> Sent: Friday, March 13, 2009 1:44 AM
> To: Steve Lime
> Cc: ruijgomes at gmail.com; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] NQuery problem
> Hi
> Here's how the layer looks in my mapfile:
> layer
>   name abc
>   connectiontype postgis
>   connection "user= user dbname=xyz host=localhost"
>   type point
>   tolerance 20
>     group world
>     dump true
>     METADATA
>        "wfs_title" "Factbook Metadata"
>        "gml_include_items" "all"
>        "wms_feature_info_mime_type" "text/html"
>     END
>     template "template.html"
>     projection
>       "init=epsg:4326"
>     end
>     transparency 65
>     status on
>   data "topology from tablename using unique id using SRID = -1"
>   classitem "veg_class"
>         class
>                 name "AGRICULTURE"
>                 expression "AGRICULTURE"
>                 style
>                         symbol 'custom_icon'
>                         size 20
>                         color 179 189 209
>                         outlinecolor 000 000 000
>                 end
>         end
> end
> Status is on and template is defined.
> Am i missing something else?
> Thanks a lot for the help.
> Subha
> Steve Lime wrote:
>> For a layer to be queryable you have to:
>>   1 - either set Status DEFAULT, or explicitly turn it on (e.g.
> layer=abc)
>>   2 - define the layer TEMPLATE property
>> Are those true?
>> Steve
>>>>> Subha Ramakrishnan <subha at gslab.com> 03/13/09 12:38 AM >>>
>> Hi,
>> I am also facing a similar problem. It doesn't throw an error but it
>> doesn't give me a result either.
>> My url looks like this :
>> http://localhost/cgi-bin/mapserv?MAP=abc.map&MODE=nquery&LAYERS=abc&im
>> gext=8920506.9477+3496535.4213+8954750.736418456+3530779.2100573704&im
>> gbox=657+209+686+239&imgxy=670+230
>> The extent given here is within  the map extent.
>> Can you please tell me if there's some mistake here?
>> Thanks a lot.
>> Subha
>> Steve Lime wrote:
>>> Nquery doesn't require qstring validation. What does your URL look
>>> like?
>>> Steve
>>>>>> Rui Gomes <ruijgomes at gmail.com> 03/12/09 9:42 PM >>>
>>> I try to use the nquery function and i recived the follow error
>>> message:
>>> mapserv(): Web application error. Metadata qstring_validation_pattern
>>> is not set.
>>> To avoid this i insert in the mapfile the follow lines inr the layer
>>> i want to query:
>>> METADATA
>>>           qstring_validation_pattern '.'
>>> END
>>> What this lines means. Why i have to put it?
>>> Thanks
