[mapserver-users] NQuery problem
subha at gslab.com subha at gslab.com
Sat Mar 14 03:20:45 EDT 2009
I do get the WMS layer alone giving me the points on the map.
My tablename is not really "tablename".Changed it for privacy
reasons.That's all.
So, if my statement looks like what you have mentioned,how would the
nquery request be?
Thanks a lot for your help.
Subha
> I was thinking of something like this for your data statement:
> DATA "the_geom from (select w.majwsh_geom as the_geom, w.oid as oid,
> w.name from watershed as w) using unique oid using srid=26915"
> A more basic question for you:
> Is your geometry column really named 'topology' and your table name
> really 'tablename'?
> Before you try to query this layer or get it to be served in a WMS, can
> you just get the geometry to draw on the map?
> David.
> -----Original Message-----
> From: Subha Ramakrishnan [mailto:subha at gslab.com]
> Sent: Friday, March 13, 2009 10:13 AM
> To: Fawcett, David
> Cc: Steve Lime; ruijgomes at gmail.com; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] NQuery problem
> Hi David,
> Thanks a lot for the reply.
> It would be great if you can give me an example url.
> Thanks & regards,
> Subha
> Fawcett, David wrote:
>> Subha,
>> In taking a quick look at your layer, I think that you have a problem
>> with your data statement.  I am quite sure that if you want to use an
>> attribute(column) from your data layer for classification or query
>> results, you need to explicitly include the name of that column in the
>> select query that is in your data statement.
>> David.
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Subha
>> Ramakrishnan
>> Sent: Friday, March 13, 2009 1:44 AM
>> To: Steve Lime
>> Cc: ruijgomes at gmail.com; mapserver-users at lists.osgeo.org
>> Hi
>> Here's how the layer looks in my mapfile:
>> layer
>>   name abc
>>   connectiontype postgis
>>   connection "user= user dbname=xyz host=localhost"
>>   type point
>>   tolerance 20
>>     group world
>>     dump true
>>     METADATA
>>        "wfs_title" "Factbook Metadata"
>>        "gml_include_items" "all"
>>        "wms_feature_info_mime_type" "text/html"
>>     END
>>     template "template.html"
>>     projection
>>       "init=epsg:4326"
>>     end
>>     transparency 65
>>     status on
>>   data "topology from tablename using unique id using SRID = -1"
>>   classitem "veg_class"
>>         class
>>                 name "AGRICULTURE"
>>                 expression "AGRICULTURE"
>>                 style
>>                         symbol 'custom_icon'
>>                         size 20
>>                         color 179 189 209
>>                         outlinecolor 000 000 000
>>                 end
>>         end
>> end
>> Status is on and template is defined.
>> Am i missing something else?
>> Thanks a lot for the help.
>> Subha
>> Steve Lime wrote:
>>> For a layer to be queryable you have to:
>>>   1 - either set Status DEFAULT, or explicitly turn it on (e.g.
>> layer=abc)
>>>   2 - define the layer TEMPLATE property
>>> Are those true?
>>> Steve
>>>>>> Subha Ramakrishnan <subha at gslab.com> 03/13/09 12:38 AM >>>
>>> Hi,
>>> I am also facing a similar problem. It doesn't throw an error but it
>>> doesn't give me a result either.
>>> My url looks like this :
> http://localhost/cgi-bin/mapserv?MAP=abc.map&MODEquery&LAYERS=abc&im
> gext=8920506.9477+3496535.4213+8954750.736418456+3530779.2100573704&im
>>> gbox=657+209+686+239&imgxy=670+230
>>> The extent given here is within  the map extent.
>>> Can you please tell me if there's some mistake here?
>>> Thanks a lot.
>>> Subha
>>> Steve Lime wrote:
>>>> Nquery doesn't require qstring validation. What does your URL look
>>>> like?
>>>> Steve
>>>>>>> Rui Gomes <ruijgomes at gmail.com> 03/12/09 9:42 PM >>>
>>>> I try to use the nquery function and i recived the follow error
>>>> message:
>>>> mapserv(): Web application error. Metadata
>>>> qstring_validation_pattern
>>>> is not set.
>>>> To avoid this i insert in the mapfile the follow lines inr the layer
>>>> i want to query:
>>>> METADATA
>>>>           qstring_validation_pattern '.'
>>>> END
>>>> What this lines means. Why i have to put it?
>>>> Thanks
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
