[mapserver-users] cannot able to test the mapfile-database eror
Venkat Rao Tammineni vtammineni at roulacglobal.com
Mon Mar 16 03:06:45 EDT 2009
    The Problem may be either u don't have  geom. Or find out whether geom.
Field is existed or not ? or you have to use SRID.Please check my map file
below I have given
MAP
  NAME Test
  STATUS ON
  SIZE 650 400
  UNITS dd
  IMAGECOLOR 102 153 153
  EXTENT 64.881 5.469 97.898 37.762
  PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
SYMBOL
  NAME "border"
  TYPE VECTOR
  POINTS
    0 0
    1 0
    1 0.8
    0 0.8
    0 0
  END
  STYLE
    10 6 1 6
  END
  FILLED TRUE
END
  # Background color for the map canvas -- change as desired
 # IMAGECOLOR 192 192 192
  IMAGEQUALITY 95
  IMAGETYPE png
          OUTPUTFORMAT
                   NAME jpeg
                   DRIVER "GD/JPEG"
                   MIMETYPE "image/jpeg"
                   IMAGEMODE RGB
                   EXTENSION "jpg"
                END
SCALEBAR
INTERVALS 2
UNITS kilometers
STYLE 1
POSITION lc
STATUS embed
  LABEL
    SIZE small
    COLOR 0 0 0
  END
END
LAYER
    NAME "India"
    TYPE POLYGON
    CONNECTIONTYPE POSTGIS
    CONNECTION "host=localhost   dbname=GIS  password=administrator
user=postgres port=5432"
Data "the_geom from (select
gid,name,pincode,district,address,website,phnumber,areaname,category,longitu
de,latitude,metroname,the_geom from indiaparks) as Foo USING UNIQUE gid
USING 'srid=24047'"
    STATUS ON
    TRANSPARENCY 40
    MinScale 7054330
   LABELITEM "cntry_name" #label Item
   CLASSITEM "cntry_name"
   TEMPLATE "query.html"
   CLASS
      NAME 'India'
       STYLE
         SYMBOL "border"
         SIZE 6
         OUTLINECOLOR 0 0 0
         COLOR 251 252 179
                END
                  LABEL  #label class start
                      POSITION auto #label Position
          FONT sans
                      SIZE SMALL #lable size
              COLOR 0 38 237 # label color
            END           # label end
       END
    END
  END
END
Thanks
Venkat.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of syed mohseen
Sent: Monday, March 16, 2009 11:01 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] cannot able to test the mapfile-database eror
hi all,
    i am a new bie to fgs and i want to test one of my mapfile with
connecting to my database.
    here is my mapfile
NAME "test"
SIZE 800 600
IMAGECOLOR 249 245 186
IMAGETYPE png
EXTENT -1.00 -1.00 1.00 1.00
LAYER
    CONNECTIONTYPE postgis
    NAME "test"
    CONNECTION "user=postgres password=hellopostgres dbname=postgres
host=localhost"
    DATA "geom FROM test"
    STATUS ON
    TYPE POINT
   END
END
whenever i test the file as shp2img i get the following error
msDrawMap(): Image handling error. Failed to draw layer named 'test'. <br>
prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(geom)),'NDR'),OID::text from test WHERE
geom && setSRID('BOX3D(-1.3338898163606 -1,1.3338898163606 1)'::BOX3D,
find_srid('','test','geom') )'
Postgresql reports the error as 'ERROR:  find_srid() - couldnt find the
corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS
table?  Is there an uppercase/lowercase missmatch?
More Help:
Error with POSTGIS data variable. You specified 'check your .map file'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (sub query) as foo using unique column name using
SRID=srid#'
Make sure you put in the 'using unique  column name' and 'using SRID=#'
clauses in.
For more help, please see http://postgis.refractions.net/documentation/
Mappostgis.c - version of Jan 23/2004.
 <br>
   any solutions will be appreciated
   regards
   SyedMohseen
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090316/7d2c12e0/attachment-0001.html
