[mapserver-users] msQueryByAttributes - regex problem
mapserver at gismap.ch
Mon Mar 16 17:50:58 EDT 2009
Hi list
I'm facing a problem using msQueryByAttributes. I'm still using
php/mapscript v4.0.2.
If I search for a string ending with UF or uf, f.e. 525UF, I get the
following message: Warning: [MapServer Error]: msQueryByAttributes(): No
matching record(s) found. in [...]. The entry 525UF is definitely there!
I did some debugging and it seams that this problem has to do with php.
I'm still using php 4.3.10. At the time I compiled php, we were forced to
compile php with regex=system. If I remember well, this was due to some
unresolved problems in the code of mapserver.
I would like to avoid an upgrade of php and mapserver right now. Is there
a way to solve this problem?
Kind regards,
Roman
