[mapserver-users] Two questions about WMS and outputformats
paalkr pal.kristensen at statkart.no
Tue Mar 17 14:54:20 EDT 2009
Hi!
Is there a way to prevent the default outputformats to be exposed in the
capabilities document? I have a map service where I have used AGG specific
rendering capabilities, and requesting e.g a GIF image then makes a bad
looking map and does not make sense. I would like the opportunity to only
expose explicit defined formats specified with one or more OUTPUTFORMAT
blocks.
I don't want to disable the different drivers though, only control the
outputformat list in the GetCapabilities response. If the only way to
achieve this is to patch the source code, I would be glade if any of the
devs could point me in the right direction.
Regards,
Pål Kristensen
Frank Warmerdam wrote:
> Rahkonen Jukka wrote:
>> Hi,
>> By default, without having any OUTPUTFORMAT sections in the mapfile,
>> Mapserver is advertising following imageformats in WMS GetCapabilities
>> document:
>>  <GetMap>
>>       <Format>image/gif</Format>
>>       <Format>image/png</Format>
>>       <Format>image/png; mode=24bit</Format>
>>       <Format>image/jpeg</Format>
>>       <Format>image/vnd.wap.wbmp</Format>
>>       <Format>image/tiff</Format>
>>       <Format>image/svg+xml</Format>
View this message in context: http://n2.nabble.com/Re%3A-Two-questions-about-WMS-and-outputformats-tp2486969p2493151.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
