[mapserver-users] WFS and PostGIS newbie question
SeeJay hendrix.cj at gmail.com
Wed Mar 18 17:21:01 EDT 2009
Pal,
Thanks for pointing me to these documents.  Let me summarize what I learned
in case it may help others just getting started with Mapserver WFS.
The fact that Mapserver can be used both as a WFS server and a WFS client
had confused some of the entries in my mapfile.  To use Mapserver as WFS
SERVER (with PostGIS data), the mapfile needs to include the WFS metadata
entries for the MAP object as well as some WFS metadata entries for the
LAYER object.  These entries are well demonstrated in the documents you
forwarded.  CONNECTIONTYPE and the DATA statements will be the same as for
WMS layers that connect to PostGIS.
It is possible to mix WMS and WFS layers in the same map file, but when
using those layers with OpenLayers, the WMS and WFS OpenLayers.Layers must
be created and added to the OpenLayers.Map object separately.
Thanks for the speedy and helpful response.
--CJ
paalkr wrote:
> Hi!
> CONNECTIONTYPE WFS is used when MapServer acts as a WFS client, i.e
> consuming a WFS service. If I understood you correctly, you are trying to
> serve out a WFS service with data stored in PostgreSQL/PostGIS. I think
> the following documents should be of great help to you:
> WFS server howto: http://mapserver.org/ogc/wfs_server.html
> Data input/PostGIS: http://mapserver.org/input/vector/postgis.html
> Regards,
> Pål Kristensen
> SeeJay wrote:
>> I'm trying to learn Mapserver/OpenLayers/PostGIS and have made slow but
>> steady progress so far.  But I'm pretty stuck now.
>> I'm trying to create my first WFS using point data stored in PostGIS.
>> From the examples I have seen on the web it seems that CONNECTIONTYPE has
>> to be WFS, but I can't figure out where I specifiy the PostGIS connection
>> parameters?  Can someone post an example of what this should look like?
>> Thanks,
>> CJ
View this message in context: http://n2.nabble.com/WFS-and-PostGIS-newbie-question-tp2493398p2499747.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090318/af4b816b/attachment.html
