[mapserver-users] Mapserver WCS - how to return native pixel resolution data?
Steve Lime Steve.Lime at dnr.state.mn.us
Thu Mar 19 18:04:14 EDT 2009
Are you seeing the issue with both WCS 1.0 and WCS 1.1? I could have
sworn I fixed WCS 1.0 back at the 5.0 but
perhaps the merge of the WCS 1.1 support broke that. There is code in
mapwcs.c to account for the differences in
various pixel models (MapServer, WCS 1.0 and WCS 1.1).
Steve
>>> On 3/19/2009 at 3:59 PM, in message
<9c2015090903191359y4c54cb4dne65f87645d79617 at mail.gmail.com>, Roger
André
<randre at gmail.com> wrote:
> You're right, 1/2 pixel offset is definitely present. What a pain.
> Any idea when the 5.4 stable release is expected?  I see that a beta
> release is available currently.
> On Thu, Mar 19, 2009 at 1:55 PM, Roger André <randre at gmail.com>
wrote:
>> Sure thing.  Here are the OUTPUTFORMAT declarations I have:
>> OUTPUTFORMAT
>>  NAME "GEOTIFF_FLOAT"
>>  DRIVER 'GDAL/GTiff'
>>  MIMETYPE 'image/tiff'
>>  IMAGEMODE FLOAT32
>>  EXTENSION 'tif'
>> END
>> OUTPUTFORMAT
>>  NAME "ASCII_GRID"
>>  DRIVER 'GDAL/AAIGrid'
>>  MIMETYPE 'image/grid'
>>  IMAGEMODE FLOAT32
>>  EXTENSION 'asc'
>> END
>> I'll have to check my output data more closely to see if the 1/2
pixel
>> offset exists.  I've only looked at it in a cursory way so far.
The
>> version of MapServer I'm using is 5.2.0
>> On Thu, Mar 19, 2009 at 12:14 PM, Alexander Petkov
<greenkov at gmail.com> wrote:
>>> On Thu, Mar 19, 2009 at 12:48 PM, Roger André <randre at gmail.com>
wrote:
>>>> Sorry for the spam, I think I found the answer.  Both RESX and
RESY
>>>> need to be positive values.  Using that, I am able to get back
data
>>>> that matches the original data.
>>>> Thanks,
>>>> Roger
>>>> On Thu, Mar 19, 2009 at 11:36 AM, Roger André <randre at gmail.com>
wrote:
>>>>> Hi Alexander,
>>>>> Thanks for the response.  Yes, I am using a GetCoverage request
that
>>>>> looks like this:
http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/netCDF/netcdf.map
>>>>> &SERVICE=wcs
>>>>> &VERSION=1.0.0
>>>>> &REQUEST=GetCoverage
>>>>> &COVERAGE=elev
>>>>> &CRS=EPSG:4326
>>>>> &BBOX=125,50,130,55
>>>>> &WIDTH=600
>>>>> &HEIGHT=600
>>>>> &FORMAT=image/grid
>>>>> The source is a single-band image, and the data is correctly
returned
>>>>> as either a single-band GeoTIFF, or an ASCII Grid, depending on
which
>>>>> FORMAT I specify in the WCS string.
>>>>> What I would like to do is eliminate the WIDTH and HEIGHT
parameters
>>>>> from the request, and just return whatever is available in the
BBOX
>>>>> area.  When I remove them from the request, I get an error that
says I
>>>>> either need HEIGHT and WIDTH, or RESX and RESY.  When I
restructure
>>>>> the command to include RESX and RESY (see below), I get an "Out
of
>>>>> memory" error.
>>>>> &SERVICE=wcs
>>>>> &VERSION=1.0.0
>>>>> &COVERAGE=elev
>>>>> &CRS=EPSG:4326
>>>>> &BBOX=125,50,130,55
>>>>> &FORMAT=image/grid
>>>>> &RESX=.033&RESY=-.033
>>>>> I believe I should be able to use the pixel dimensions that are
>>>>> reported back to me in a DescribeCoverage request, which show
them to
>>>>> be:
>>>>> <gml:offsetVector>0.033333333333333 0</gml:offsetVector>
>>>>> <gml:offsetVector>0 -0.033333333333333</gml:offsetVector>
>>>>> Thanks for the help,
>>>>> Roger
>>> Hi Roger:
>>> Glad to know that you got the problem solved. Do you mind sharing
your
>>> OUTPUTFORMAT configurations in your mapfile if you have them
>>> configured, particularly for the ASCII grid format.
>>> Also, are you using a mapserver release older than any of the 5.4
>>> betas? I am using 5.2.1 and I see the result of the GetCoverage
>>> request being offset by a half pixel (the pixel size of my data).
Bug
>>> reports indicate that this offset will be fixed for the 5.4
release.
>>> Thanks in advance,
>>> Alex
> mapserver-users at lists.osgeo.org
