[mapserver-users] mapserver install on solaris
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Mon Mar 23 08:16:11 EDT 2009
In general you don't copy your php extension to your web root. You need
to copy it to your PHP extensions directory. You'll find what this is
set to in your php.ini file. When you try to dynamically load the module
it's looking to load it from the php default extensions path and not the
web root path. In my case I actually added right to my php.ini to have
it load the extension.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Pwint Phyu
Aung
Sent: Monday, March 23, 2009 12:43 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] mapserver install on solaris
Hi there!
I'm installing Map server version 5.0.x in my Unix (solaris
Intel) server.
I installed apache built-in and mysql and php 4.4.7
Then download and install map server by compiling:
>./configure --with-gd=/usr/local --with-freetype=/usr/local
--with-zlib=/usr/local --with-png=/usr/local --with-jpeg=/usr/local
--with-tiff=/usr/local --enable-perlv-ld-detect --with-proj
--with-ogr=/usr/local --with-tiff=/usr/local --with-libiconv=/usr
--with-xml2-config=/usr/bin/xml2-config
--with-php=/usr/local/include/php --with-gdal=/usr/local/bin/gdal-config
and
>make
and then, to load the php_mapscript.so, copy that file into my web
folder cp mapscript/php3/php_mapscript.so /webfolder
and runt he script to test.
<HTML>
<BODY>
<?php
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
dl("php_mapscript.dll");
else
dl("php_mapscript.so");
phpinfo();
</BODY>
</HTML>
But the map script information is not showing in php info file.
How to fix the problem?
Please help me.
