[mapserver-users] queryByAttribute in C# mapscript
Tamas Szekeres
szekerest at gmail.com
Tue Mar 24 11:41:34 EDT 2009
You might want to test with the:
"('[Name]'='value')"
expression syntax.
Best regards,
Tamas
2009/3/24 Murty Maganti <MMaganti at oriongis.com>
> Hi
> Here is the entry in map file (removed CLASS portion)
> LAYER
> CONNECTION "vmonp03,port:5154,dmtigdb,dmtigdb,password"
> CONNECTIONTYPE PLUGIN
> PLUGIN "msplugin_sde_92.dll"
> DATA "DMTIGDB.CANLUR,SHAPE,SDE.DEFAULT"
> NAME "Canlur"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> CLASS
> END
> END
> I think the parsing error is coming from query expression. If I use
> PARCELD=123, then it writes ‘Parsing error near(PARCELID)’ to log.
> Thanks
> Murty
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Tuesday, March 24, 2009 11:17 AM
> *To:* Murty Maganti
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] queryByAttribute in C# mapscript
> How is your mapfile looking like. Parsing error near (OBJECTID) seems a bit
> strange here....
> Best regards,
> Tamas
> Hi
> I am using queryByAttribute on a SDE layer with a simple expression,
> ‘OBJECTID = 750’. The method returns MS_FAILURE, though it is valid
> expression. I can run same query in ArcCatalog and get the result back.
> What do I need to verify here. I usually I check that there is template
> name defined and maxscaledenom is set to -1. What else I am missing.
> This is what is logged by map server
> [Mon Mar 23 18:02:25 2009].834000
> msConnPoolRequest(Canlur,vmonp03,port:5154,dmtigdb,dmtigdb,password) -> got
> 1D49DFF8
> [Mon Mar 23 18:02:25 2009].834000 msSDELayerOpen(): Layer Canlur specified
> version SDE.DEFAULT.
> [Mon Mar 23 18:02:25 2009].834000 msSDEGetLayerInfo(): Looking for layer by
> TESTGDB.CANLUR, SHAPE, vmonp03,port:5154,dmtigdb,dmtigdb,password
> [Mon Mar 23 18:02:25 2009].834000 msSDEGetLayerId(): Matched layer to id
> 112.
> [Mon Mar 23 18:02:25 2009].834000 Getting all column information in
> msSDELayerInitItemInfo
> [Mon Mar 23 18:02:25 2009].834000 msSDELayerInitItemInfo(): getting info
> for OBJECTID
> for CATEGORY
> for SHAPE
> for OID
> [Mon Mar 23 18:02:35 2009].338000 getSymbol(): Symbol definition error.
> Parsing error near (OBJECTID):(line 831)
> [Mon Mar 23 18:02:35 2009].370000 msQueryByAttributes(): Search returned no
> results. No matching record(s) found.
> I used another field PARCELID, which is also numeric but still does not
> work.
> Thanks
> Murty
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090324/ce7647e4/attachment-0001.html
