[mapserver-users] WMS and transparent
Fischer, Brian
bfischer at houstoneng.com
Wed Mar 25 10:50:19 EDT 2009
Thanks for the reply. I was hoping maybe MapServer could consume that
jpeg and set the white color to transparent, then mapserver would output
a PNG that has transparency to the web client. Does the offsite
parameter do this by chance or is there another trick that could be
used?
-----Original Message-----
From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
Sent: Wednesday, March 25, 2009 9:47 AM
To: Fischer, Brian
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WMS and transparent
jpegs can not be transparent. Only if you switch to another image format
like image/png.
Best regards,
Bart
> I am trying to consume this WMS service with MapServer 5.0.2 as a
> client and would like to make the background transparent instead of
> white. Is this possible mapserver? I tried the "wms_transparent"
> "true", but that didn't seem to work. Thanks for any suggestions.
> NAME '2003orthos'
> STATUS ON
> EXTENT 366751.468 5034450.028 882880.091 5434570.553
> UNITS Meters
> SIZE 600 400
> FONTSET '../fonts/fontset.list'
> SYMBOLSET '../symbols/symbol.sym'
> IMAGETYPE PNG24
> TRANSPARENT TRUE
> WEB
> IMAGEURL "E:\ms4w\tmp\ms_tmp"
> IMAGEPATH "E:\ms4w\tmp\ms_tmp"
> END
> LAYER
> NAME ND03
> TYPE RASTER
> OFFSITE 0 0 0
> STATUS DEFAULT
> CONNECTIONTYPE WMS
> CONNECTION
"http://web.apps.state.nd.us/wmsconnector/com.esri.wms.Esrimap/NDWMS_aer
> ialimages?"
> #MINSCALE 1000 # only display down to this scale
> #MAXSCALE 24000
> METADATA
> "wms_srs" "EPSG:26914"
> "wms_name" "ND03"
> "wms_server_version" "1.1.1"
> "wms_format" "image/jpeg"
> "wms_styles" ""
> "wms_exceptions" "application/vnd.ogc.se_inimage"
> END
> END
> END
> End #Map
> Thanks,
> Brian
