[mapserver-users] ogr/mysql: trim spaces/padding for numeric fields?
P.Romero
romero619 at hotmail.com
Sat Mar 28 13:39:13 EDT 2009
Im trying to use ogr's mysql driver to create a points layer that will be
converted to an imagemap.
Im using the following template to create the imagemap:
<map id="mymap" name="mymap">
[resultset layer=mypoints]
[feature]
<area shape="circle" coords="[shpxy precision=0 proj=image yf=",7" xf=","]"
title="[buoyName]-[lat],[lon]" href="#" alt="[buoyName]-[lat],[lon]">
[/feature]
[/resultset]
<map>
the problem is that ogr pads numeric mysql fields with a very large amount
of whitespace. Here is some of my output:
<area
shape="circle"
coords="178,274,7"
title="42055: 2@ 160"
href="#"
alt="42055: 2@ 160"
the (double) numeric fields [lat] and [lon] are being left-padded with a lot
of whitespace (each field is 22 spaces long in total).
running my ovf file from the command line with ogrinfo produces the same
result; a lot of unecessary left-padding.
OGRFeature(mypoints):88
max(recTS) (Integer) = 1238258520
buoyName (String) = 41114
lat (Real) = 28
lon (Real) = -80
MAG (Real) = -371
WDIR (Real) = -99
WSPD (Real) = -99
ADIR (Real) = 81
ts (DateTime) = 2009/03/13 11:42:00
POINT (-80.219999999999999 27.55 0)
Ogr's output also shows the 20+space left-padding for the double&int fields.
Im trying to access my imagemap using a url in this format:
http://localhost/cgi-bin/mapserv?map=/data/www/html/test/test.map
<http://localhost/cgi-bin/mapserv?map=/data/www/html/test/test.map&mode=nque
ry&searchmap=true> &mode=nquery&searchmap=true
I also tried embedding php code to try to preprocess the variables:
[feature]
title="[buoyName]-<?php trim([lat]):>,[lon]" href="#"
[/feature]
[/resultset]
<map>
but this obviously didn't work, Im assuming since cgi was processing &
returning the results, so php was never even called upon.
Questions:
How can I remove this padding?
Is this padding by design, or a bug in ogrinfo?
Is there any other way that I can pre-process these variables prior to
sending them to the browser, (using php or some other means) so that I can
process&format them based on my needs?
Please help,
Thanks,
P.Romero
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090328/97083077/attachment.html
