[mapserver-users] imagemaps using php mapscript?
P. R.M.
romero619 at hotmail.com
Sat Mar 28 16:08:27 EDT 2009
thanks, but that didnt help much.
I have this:
$map = ms_newMapObj("/data/www/html/test/test.map");
$img=$map->draw();
$tmparray["img_url"] = $img->saveWebImage();
# remove '/data/www/html' directory prefix
# from the resulting url string
$tmparray["img_url"] = substr($tmparray["img_url"],14,strlen($tmparray["img_url"]));
$html=$map->processquerytemplate($tmparray);
echo $html;
However, the processquerytemplate() function is not processing the data in my points layer.
the imagemap html tags are empty, even though the points from my points layer are correctly being drawn on the map image.
Here's the relevant sections of my mapfile, including my points layer:
OUTPUTFORMAT
NAME 'html'
DRIVER 'TEMPLATE'
MIMETYPE 'text/html'
FORMATOPTION 'FILE=/data/www/html/test/testmap.html'
END
QUERYMAP
STATUS ON
STYLE NORMAL
END
WEB
QUERYFORMAT 'html'
LOG "/data/www/html/test/mslog"
IMAGEPATH "/data/www/html/images/mapserver/tmp/"
IMAGEURL "/data/www/html/images/mapserver/tmp/"
MAXSCALE 15500000
END
LAYER
NAME "mypoints"
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "test.ovf"
DATA "mypoints"
TYPE POINT
TEMPLATE "/data/www/html/test/testmap.html"
CLASS
NAME "None"
STYLE
SYMBOL 'arrow'
ANGLE [ADIR]
SIZE [MAG]
END
END
END
the documentation says that the processquerytemplate() function apparently only processes at the mapobject layer, so it doesnt seem to process each layer. Is this correct?
How can I process the html template file using the points in my points layer?
Please help,
Thanks,
P.Romero
> Date: Sat, 28 Mar 2009 21:29:35 +0200
> Subject: Re: [mapserver-users] imagemaps using php mapscript?
> From: iacovlev.pavel at gmail.com
> To: romero619 at hotmail.com
> $image = $map->draw();
> ob_start();
> $image->saveimage('');
> $image = imagecreatefromstring(ob_get_contents());
> $contents = ob_get_contents();
> ob_end_clean();
> imagepng($image);
> 2009/3/28 P.Romero>
> How can this example:
> http://mapserver.org/output/imagemaps.html?highlight=imagemap
> be implemented using php mapscript?
> More specifically, how can the html output for the imagemap
> be separated from the imageobject, and stored into a php variable?
> Im hoping for something like….
> $map = ms_newMapObj("mymapfile.map");
> $map_img=$img=$map->draw();
> $imagemap_html=$map->get_html_output();
> ...and then I can separately handle the image & html
> output.
> Is this possible?
> Please help,
> Thanks,
> P.Romero
> mapserver-users at lists.osgeo.org
> http://iap.md, The future is open
_________________________________________________________________
Express your personality in color! Preview and select themes for Hotmail®.
http://www.windowslive-hotmail.com/LearnMore/personalize.aspx?ocid=TXT_MSGTX_WL_HM_express_032009#colortheme
