[mapserver-users] Using the SQL Server 2008 Plugin with a Geography column
joncoign jncoign at Knology.net
Tue Mar 31 18:35:28 EDT 2009
Has anyone been able to get the SQL Server 2008 plugin to work against a geography column.
I have been using the following DATA Statement
DATA "the_geom FROM Types USING UNIQUE ID USING SRID=4326"
and get the response, "sys.geometry is incompatible with sys.geography" due to the spatial filter being written by the plugin using geometry.
Is there an option to change this? I have been unable to locate any detailed documetation on SQL Server 2008 plugin so if this exists that might help.
View this message in context: http://n2.nabble.com/Using-the-SQL-Server-2008-Plugin-with-a-Geography-column-tp2565867p2565867.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
