[mapserver-users] WFS Layer running OGR Query Multiple timesperrequest
Steve Lime Steve.Lime at dnr.state.mn.us
Tue Mar 31 22:18:29 EDT 2009
It's particularly hard on the database backends because of the overhead of
running so many small queries. I should note that a true single pass query is
not easy to achieve. Many presentation methods, for example WFS/GML
require a result set size at the start of a file which all but requires two
passes over the data.  The most recent strategy involves two-passes but on
the same statement handle. At the recent code sprint we tested with Oracle
Spatial and PostGIS, both with significant improvements in performance. I'll
probably also add a small feature cache to avoid resetting the statement
handle in a majority of cases.
I'm not sure how the OGR driver will need to be updated though.
The sprint modifications are implemented in the MapServer sandbox:
  http://svn.osgeo.org/mapserver/sandbox/single-pass/mapserver/
Steve
>>> Frank Warmerdam <warmerdam at pobox.com> 03/31/09 8:32 PM >>>
Robert Sanson wrote:
> Sounds like quite an impediment. Any idea when v6.0 is likely to be
> released?
Robert,
I would say late summer or early fall.  However, I would also encourage
you to try out the single-pass-query in the development version before
then. I don't think this is available yet though.
Best regards,
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
