[mapserver-users] MapServer 5.4 WMS Server VERSION=1.3.0 Problem
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon May 4 12:16:04 EDT 2009
Do you have the full URL that is received by the server?
MapServer WMS 1.3.0 supports the following EXCEPTIONS : XML, INIMAGE,
or BLANK.
Is might be possible to add EXCEPTIONS: "XML" (or INIMAGE, or BLANK)
when building your OL wms 1.3.0 layer?
Best Regards,
Ben Madin wrote:
> G'day all,
> I'm a little new to WMS, but I confess the GetLegendGraphic feature
> available now in the 5.4 release caught my eye.
> So I'm 5.4.0 and using OpenLayers 2.7. However, when I use the URL :
> /cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&
> I get the following message (embedded in the tile) :
> msWMSLoadGetMapParams(): WMS server error. Invalid format for the
> EXCEPTION parameter.
> If I drop the VERSION (either back to 1.1.1 or just completely loose it,
> text below in the context of the OL script.
> var pol_bnd = new OpenLayers.Layer.WMS(
> 'Countries',
> 'http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&',
> {layers: 'countries'}
> map.addLayer(pol_bnd);
> I get my maps.
> I can work with this for now, but is there something I'm missing. I did
> try fiddling with the reported CRS / SRS changes, but I think I just
> confused myself - but that would be another topic!
> Perhaps along with the mapfile in the documentation, a copy of a full
> example of a request url would be great.
> Some of the mapfile is attached for completeness (it has been sucked
> across from a CGI Mapserv application):
> MAP
> NAME aus_boundaries
> STATUS ON
> UNITS DD
> EXTENT 110 -35 130 -12 # WA extents
> SIZE 900 650
> SHAPEPATH "../geodata/"
> FONTSET "../geodata/fonts/fonts.lst"
> SYMBOLSET "../trade.sym"
> IMAGECOLOR 230 240 255
> CONFIG "MS_ERRORFILE" "/var/log/mserr.log"
> DEBUG 5
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> "wms_title" "GMS Livestock Trade"
> "wms_onlineresource"
> "http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/ol_countries_wms.map&"
> "wms_srs" "EPSG:4326"
> END
> IMAGEPATH "../../tmp/"
> IMAGEURL "../../tmp/"
> END
> LAYER
> METADATA
> "wms_title" "Country Boundaries"
> "wms_group_title" "Political"
> END
> STATUS ON
> NAME "countries"
> GROUP "Political"
> DATA "global/ctybnda"
> TYPE polygon
> OPACITY 100
> CLASS
> NAME "Country Borders"
> COLOR 240 240 180
> OUTLINECOLOR 0 70 0
> END
> END
> cheers
> Ben
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
