[mapserver-users] MapServer 5.4 WMS Server VERSION=1.3.0 Problem
Ben Madin ben at remoteinformation.com.au
Mon May 4 20:31:57 EDT 2009
G'day Assefa,
On 05/05/2009, at 12:16 AM, Yewondwossen Assefa wrote:
> Do you have the full URL that is received by the server?
No... I'm not sure how to get this(?) - I thought it might be shown if
I set the debug levels high enough, but so far no luck!
> MapServer WMS 1.3.0 supports the following EXCEPTIONS : XML,
> INIMAGE, or BLANK.
> Is might be  possible to add  EXCEPTIONS: "XML" (or INIMAGE, or
> BLANK)   when building your OL wms 1.3.0 layer?
using either :
new OpenLayers.Layer.WMS( 'Countries',
	'http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&VERSION=1.3.0&EXCEPTIONS=INIMAGE&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&'
                 {layers: 'countries'} );
or
new OpenLayers.Layer.WMS( 'Tail Tag Areas',
	'http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&REQUEST=GetMap&STYLES=&SRS=EPSG:4326'
               {layers: 'tailtagareas', transparent: 'true', version:
'1.3.0', exceptions: 'xml'}         );
gives no error, but neither do I receive any images any more.
using the url (such as in the first example) works fine in QGIS, so
I'm guessing the web serving 'can' work... very confusing.
cheers
Ben
> Ben Madin wrote:
>> G'day all,
>> I'm a little new to WMS, but I confess the GetLegendGraphic feature
>> available now in the 5.4 release caught my eye.
>> So I'm 5.4.0 and using OpenLayers 2.7. However, when I use the URL :
>> layers/
>> ol_countries_wms
>> .map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&SRS=EPSG:
>> 4326& I get the following message (embedded in the tile) :
>> msWMSLoadGetMapParams(): WMS server error. Invalid format for the
>> EXCEPTION parameter.
>> If I drop the VERSION (either back to 1.1.1 or just completely
>> loose it, text below in the context of the OL script.
>> var pol_bnd = new OpenLayers.Layer.WMS(
>>    'Countries',
>>    'http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&'
>> ,                 {layers: 'countries'}
>> map.addLayer(pol_bnd);
>> I get my maps.
>> I can work with this for now, but is there something I'm missing. I
>> did try fiddling with the reported CRS / SRS changes, but I think I
>> just confused myself - but that would be another topic!
>> Perhaps along with the mapfile in the documentation, a copy of a
>> full example of a request url would be great.
>> Some of the mapfile is attached for completeness (it has been
>> sucked across from a CGI Mapserv application):
>> MAP
>>    NAME        aus_boundaries
>>    STATUS        ON
>>    UNITS        DD
>>    EXTENT      110 -35 130 -12 #  WA extents
>>    SIZE        900 650
>>    SHAPEPATH   "../geodata/"
>>    FONTSET     "../geodata/fonts/fonts.lst"
>>    SYMBOLSET   "../trade.sym"
>>    IMAGECOLOR  230 240 255
>>    CONFIG "MS_ERRORFILE" "/var/log/mserr.log"
>>    DEBUG 5
>>    PROJECTION
>>        "init=epsg:4326"
>>    END
>>    WEB
>>        METADATA
>>            "wms_title"           "GMS Livestock Trade"
>>            "wms_onlineresource"  "http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/ol_countries_wms.map&
>> "             "wms_srs"             "EPSG:4326"
>>        END
>>        IMAGEPATH   "../../tmp/"
>>        IMAGEURL    "../../tmp/"
>>    END
>>    LAYER
>>        METADATA
>>            "wms_title" "Country Boundaries"
>>            "wms_group_title" "Political"
>>        END
>>        STATUS    ON
>>        NAME    "countries"
>>        GROUP    "Political"
>>        DATA    "global/ctybnda"
>>        TYPE    polygon
>>        OPACITY 100
>>        CLASS
>>            NAME    "Country Borders"
>>            COLOR    240 240 180
>>            OUTLINECOLOR 0 70 0
>>        END
>>    END
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
