[mapserver-users] R: PHP Mapscript - Displaying only image
colour except the existing layers
zizu
manojkapil06 at gmail.com
Tue May 5 09:59:33 EDT 2009
Hi pietro,
sorry i had a problem in adding the label layer over the kerala map
layer.... unknowingly i asked the previous doubt... now i need to add this
second layer over the first one.... am getting the following error....
*Warning*: [MapServer Error]: msGetLabelSize(): Requested font (arial-bold)
not found. in *
/home/kapil/FGS-MAPSERVER/www/htdocs/mapfiles/sampletest/htdocs/test.php* on
line *8*
*Warning*: [MapServer Error]: msSearchDiskTree(): Unable to open spatial
index for
/home/kapil/FGS-MAPSERVER/www/htdocs/mapfiles/sampletest/data/parl_04.qix.
In most cases you can safely ignore this message, otherwise check file names
and permissions. in *
line *8*
*Fatal error*: Call to a member function saveWebImage() on a non-object in *
line *9
*The follwing is my PHP code...
<?php
dl('php_mapscript_5.2.1.so');
$map =
ms_newMapObj("/home/kapil/FGS-MAPSERVER/www/htdocs/mapfiles/sampletest/htdocs/test.map");
$layer=$map->getLayerByName("kerala","states_label");
$layer->set('status',MS_ON);
$image=$map->draw();
$image_url=$image->saveWebImage();
<HTML>
<HEAD>
<TITLE>Example 1: Displaying a map</TITLE>
</HEAD>
<BODY>
<IMG SRC=<?php echo $image_url; ?> >
</BODY>
</HTML>
*i guess the problem is in label layer.... please help me out...
many thanks,
zizu*
On Tue, May 5, 2009 at 7:10 PM, kapil manoj <manojkapil06 at gmail.com> wrote:
> Hi pietro,
> could you please tell me how to add the layers with the following code...
> $layer = $map->getLayerByName('kerala')
>> $layer->set('status', MS_ON);
> many thanks,
> zizu
> On Tue, May 5, 2009 at 7:01 PM, kapil manoj <manojkapil06 at gmail.com>wrote:
>> Hi pietro,
>> Thank you so much... now its works fine......
>> On Tue, May 5, 2009 at 6:07 PM, Pietro Giannini (via Nabble) <
>> ml-user+94644-1894679202 at n2.nabble.com<ml-user%2B94644-1894679202 at n2.nabble.com>
>> > wrote:
>>> Hi Zizu,
>>> STATUS OFF on all the layers of your map.
>>> To turn on:
>>> $layer = $map->getLayerByName('kerala');
>>> bye
>>> ...................pg
>>> ________________________________________
>>> Da: mapserver-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=0>[
>>> mapserver-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=1>]
>>> per conto di zizu [manojkapil06 at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=2>]
>>> Inviato: martedì 5 maggio 2009 12.59
>>> A: mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=3>
>>> Oggetto: [mapserver-users] PHP Mapscript - Displaying only image colour
>>> Dear users,
>>> I am using FGS-Mapserver, its a stand alone environment on fedora 9. i
>>> have
>>> successfully play mapserver through cgi, there is absolutely no problem
>>> with
>>> that. Now am trying to play PHP-Mapscript , example given in the
>>> tutorial.
>>> The problem am encountering right now is when i run the php file through
>>> browser
>>> http://localhost:8080/mapfiles/sampletest/htdocs/test.php
>>> Luckily the image colour of the map is displaying but the layers of the
>>> map
>>> is not displaying... herewith am attaching the screen shot of that
>>> page....
>>> am also attaching both the map file and php file for your view.....
>>> what could be a problem..... please help me out..
>>> tips will be appreciated....
>>> http://n2.nabble.com/file/n2792269/Screenshot.png Screenshot.png
>>> http://n2.nabble.com/file/n2792269/test.map test.map
>>> http://n2.nabble.com/file/n2792269/test.php test.php
>>> many thanks,
>>> zizu
>>> View this message in context:
>>> http://n2.nabble.com/PHP-Mapscript---Displaying-only-image-colour-except-the-existing-layers-tp2792269p2792269.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>> mapserver-users mailing list
>>> mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=4>
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=5>
>>> This email is a reply to your post @
>>> http://n2.nabble.com/PHP-Mapscript---Displaying-only-image-colour-except-the-existing-layers-tp2792269p2793318.html
>>> You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/PHP-Mapscript---Displaying-only-image-colour-except-the-existing-layers-tp2792269p2795451.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090505/09901c00/attachment-0001.html
