[mapserver-users] WMS Layer with secure http url
Alexandre Dube adube at mapgears.com
Wed May 6 08:39:05 EDT 2009
Thank you both for the tips, I'll try your solutions today.
Alexandre
Rahkonen Jukka wrote:
> Hi,
> When the certificate is OK the next thing to do is to change the connection URL so that it includes username and password. If I remember right the format is like https://username:password@foo.com/mapserv?....
> -Jukka Rahkonen-
> Michael Smith wrote:
> Alexandre,
> What you need is the servers root certificate added to your libcurl certs.
> Its failing on validating the servers ssl certificate.
> The curl-config should list your cert directory and then you can add your
> cert there and it should validate.
> Mike
Alexandre Dubé
Mapgears
www.mapgears.com
