[mapserver-users] GetFeatureInfo in XML
Sven Schroeter schroeter at netgis.de
Wed May 6 09:43:03 EDT 2009
Pål ,
I use a simple XML-File with CGI-Variables ([myvar]) like this:
<sg:FeatureInfoResponse>
  <sg:Schutzgebiet>
    <sg:Schutzgebietsart>Naturschutzgebiet</sg:Schutzgebietsart>
    <sg:Gebietsname>[name]</sg:Gebietsname>
    <sg:Gebietsnummer>[objnr]</sg:Gebietsnummer>
    <sg:Rechtsgrundlage>http://www.naturschutz.rlp.de/dokumente/rvo/[objnr].htm</sg:Rechtsgrundlage>
    <sg:Schutzzone>[schutzzone]</sg:Schutzzone>
    <sg:Erfassungsgrundlage>[erfassungsgrundlage]</sg:Erfassungsgrundlage>
    <sg:Info_Kontakt>http://www.naturschutz.rlp.de/Impressum.natur?ActiveID=1234</sg:Info_Kontakt>
  </sg:Schutzgebiet>
</sg:FeatureInfoResponse>
If  there is a request for xml I tell my script to set the response-header
is XML:
  $buffer = ms_iogetstdoutbufferstring();
    header('Content-type: text/xml');
    echo $buffer;
Greetings Sven
----- Original Message -----
To: <mapserver-users at lists.osgeo.org>
Sent: Tuesday, May 05, 2009 11:01 PM
Subject: Re: [mapserver-users] GetFeatureInfo in XML
Hi!
This is something that I'm interested in as well, could I please ask you to
share your featureinfo_nsg.xml? I would like to have a look at it to get
some hints on how to set up a XML template.
BTW: I think you can expose a new InfoFormat by setting the
wms_feature_info_mime_type keyword in the web metadata section of your
mapfile.
Regards,
Pål Kristensen
Sven Schroeter wrote:
> Hi all,
> I am currently experimenting with Web Map Services and a custom PHP
> wrapper.
> In this script for a GetFeatureInfo-Request with
> info_format=application/vnd.ogc.wms_xml or  info_format=text/xml a XML
> document is generated.
> This works well, a XML-template is set in the mapfile dynamically:
> if($k == 'info_format' & ($v == 'application/vnd.ogc.wms_xml' || $v ==
> 'text/xml')){
>      $layer = $oMap->getLayerByName($layername);
>      $layer->set("template", "template/featureinfo_nsg.xml");
> Two questions:
> 1. Is it possible to get a featureInfo-Request in xml native by mapserver
> (no gml)
> 2. How can I tell mapserver to enhance the list of capabilities to xml? At
> this time there comes only
> <GetFeatureInfo>
> <Format>text/plain</Format>
> <Format>text/html</Format>
> <Format>application/vnd.ogc.gml</Format>
> <DCPType>
> Thanks
> Sven
Regards,
Pål Kristensen
View this message in context:
http://n2.nabble.com/GetFeatureInfo-in-XML-tp2787413p2806255.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
