[mapserver-users] Apache crash using Mapserver with big mapfile
(about 2500 lines)
Edgardo Ghibaudo
edgardo.ghibaudo at provincia.biella.it
Thu May 7 05:31:00 EDT 2009
Dear users,
I’m using the following environment:
Ubuntu 6.06 (libc6 2.3.6)
Apache 2.2.9
Php 4.4.2
Mapserver 4.8.2
Maplab 2.2.1 (last available version)
Using a project inside Maplab/gmapfactory with a big mapfile (about 2500 lines) the httpd process of Apache crash.
Enclosed you can find the details of the crash (Backtrace).
Apache compilation details:
./configure --prefix=/usr/local/apache229 --enable-info --enable-mime-magic --enable-rewrite --enable-so --enable-speling --enable-unique_id --enable-usertrack --with-mpm=prefork
PHP compilation details:
./configure --enable-kbmmw --with-regex=system --with-freetype --with-dbase --prefix=/usr/local/apache229/php --with-mysql=/usr/local/mysql4115 --with-pgsql=shared,/usr/local/pgsql8014 --with-pdflib=shared,/usr/local/pdflite703 --with-config-file-path=/usr/local/apache229/php --with-png --with-jpeg --with-jpeg-dir=/usr/local --with-tiff --with-gd --with-zlib --enable-track-vars --enable-sockets --enable-wddx=shared --with-xmlrpc=shared --enable-calendar --with-iconv=/usr/local/libiconv112 --with-iconv-dir=/usr/local/libiconv112 --with-apxs2=/usr/local/apache229/bin/apxs --enable-cgi
Mapserver compilation details:
./configure --enable-debug --with-proj=/usr/local --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gdal-config --with-gd --with-httpd=/usr/local/apache229/bin/httpd --with-php=/usr/local/apache229/php --with-php-regex-dir=/usr/local/apache229/php/regex --enable-runpath --enable-force-freetype1 --with-wmsclient --with-freetype --with-png=/usr/local --with-jpeg=/usr/local --with-libiconv=/usr/local --with-wfs --with-wfsclient --with-postgis=/usr/local/pgsql8014/bin/pg_config
I tried to upgrade the OS version (Ubuntu 7.04 – libc6 2.5.0), but the result doesn’t change.
I tried also to compile different SW versions (Apache 1.3.41, Php 4.4.9, Mapserver 4.8.3 & 4.8.4), but the result doesn’t change
Many thanks,
Edgardo
*** glibc detected *** /usr/local/apache229/bin/httpd: free(): invalid next size (fast): 0x087bdf40 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6[0xb7d7b7cd]
/lib/tls/i686/cmov/libc.so.6(cfree+0x90)[0xb7d7ee30]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msFreeShape+0x35)[0xb7814de5]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawVectorLayer+0x336)[0xb7828ca6]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawLayer+0xaa)[0xb7828faa]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawMap+0x5d3)[0xb7829f33]
/usr/local/apache229/php/extensions/php_mapscript_44.so(mapObj_draw+0x1d)[0xb77e34dd]
/usr/local/apache229/php/extensions/php_mapscript_44.so(php3_ms_map_draw+0x6c)[0xb77db65c]
/usr/local/apache229/modules/libphp4.so(execute+0x6b43)[0xb7c7d943]
/usr/local/apache229/modules/libphp4.so(zend_execute_scripts+0xde)[0xb7c674fe]
/usr/local/apache229/modules/libphp4.so(php_execute_script+0x316)[0xb7c3b006]
/usr/local/apache229/modules/libphp4.so[0xb7c8171b]
/usr/local/apache229/bin/httpd(ap_run_handler+0x59)[0x807b1b9]
/usr/local/apache229/bin/httpd(ap_invoke_handler+0x67)[0x807e447]
/usr/local/apache229/bin/httpd(ap_process_request+0x178)[0x8098af8]
/usr/local/apache229/bin/httpd[0x8095d9b]
/usr/local/apache229/bin/httpd(ap_run_process_connection+0x59)[0x8082539]
/usr/local/apache229/bin/httpd[0x80b68f5]
/usr/local/apache229/bin/httpd[0x80b6bb7]
/usr/local/apache229/bin/httpd(ap_mpm_run+0x880)[0x80b7510]
/usr/local/apache229/bin/httpd(main+0x865)[0x8068ae5]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xdc)[0xb7d29ebc]
/usr/local/apache229/bin/httpd(apr_os_proc_mutex_put+0x5d)[0x8067ca1]
--http://www.provincia.biella.it------------------------------------------------------
Vuoi rimanere sempre aggiornato sulle nostre attivita'?
Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla sezione di interesse.
--Avviso------------------------------------------------------------------------------
Questo messaggio e i suoi allegati sono riservati esclusivamente alle persone in
indirizzo e possono contenere informazioni confidenziali. Se questo messaggio vi e'
pervenuto per errore, vi informiamo che ogni suo uso e'proibito.
In questo caso rispedite immediatamente il messaggio al mittente e cancellatelo.
Per ogni chiarimento contattateci scrivendo a ced at provincia.biella.it.
Grazie -Il Webmaster.
--Warning-----------------------------------------------------------------------------
This message and its attachments are addressed solely to the persons above and may
contain confidential information. If you have received the message in error, be
informed that any use of the content hereof is prohibited.
Please return it immediately to the sender and delete the message. Should you have
any questions, please contact us by replying to ced at provincia.biella.it.
The Webmaster.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090507/07408774/attachment.html
