[mapserver-users] Apache crash using Mapserver with big
mapfile(about 2500 lines)
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu May 7 13:28:59 EDT 2009
Have you tried running through shp2img independently of MapLab to see if
it's a problem with MapServer or
MapLab specifically?
Steve
>>> On 5/7/2009 at 4:31 AM, in message
<a3fc4ad4.1c9cef6.23e1ca.29 at provincia.biella.it>, Edgardo Ghibaudo
<edgardo.ghibaudo at provincia.biella.it> wrote:
> Dear users,
> I’m using the following environment:
> Ubuntu 6.06 (libc6 2.3.6)
> Apache 2.2.9
> Php 4.4.2
> Mapserver 4.8.2
> Maplab 2.2.1 (last available version)
> Using a project inside Maplab/gmapfactory with a big mapfile (about
2500
> lines) the httpd process of Apache crash.
> Enclosed you can find the details of the crash (Backtrace).
> Apache compilation details:
> ./configure --prefix=/usr/local/apache229 --enable-info
--enable-mime-magic
> --enable-rewrite --enable-so --enable-speling --enable-unique_id
--enable-usertrack
> --with-mpm=prefork
> PHP compilation details:
> ./configure --enable-kbmmw --with-regex=system --with-freetype
--with-dbase
> --prefix=/usr/local/apache229/php --with-mysql=/usr/local/mysql4115
> --with-pgsql=shared,/usr/local/pgsql8014
> --with-pdflib=shared,/usr/local/pdflite703
> --with-config-file-path=/usr/local/apache229/php --with-png
--with-jpeg
> --with-jpeg-dir=/usr/local --with-tiff --with-gd --with-zlib
--enable-track-vars
> --enable-sockets --enable-wddx=shared --with-xmlrpc=shared
--enable-calendar
> --with-iconv=/usr/local/libiconv112
--with-iconv-dir=/usr/local/libiconv112
> --with-apxs2=/usr/local/apache229/bin/apxs --enable-cgi
> Mapserver compilation details:
> ./configure --enable-debug --with-proj=/usr/local
> --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config
> --with-gd --with-httpd=/usr/local/apache229/bin/httpd
> --with-php=/usr/local/apache229/php
> --with-php-regex-dir=/usr/local/apache229/php/regex --enable-runpath
> --enable-force-freetype1 --with-wmsclient --with-freetype
--with-png=/usr/local
> --with-jpeg=/usr/local --with-libiconv=/usr/local --with-wfs
--with-wfsclient
> --with-postgis=/usr/local/pgsql8014/bin/pg_config
> I tried to upgrade the OS version (Ubuntu 7.04 – libc6 2.5.0), but
the
> result doesn’t change.
> I tried also to compile different SW versions (Apache 1.3.41, Php
4.4.9,
> Mapserver 4.8.3 & 4.8.4), but the result doesn’t change
> Many thanks,
> Edgardo
> *** glibc detected *** /usr/local/apache229/bin/httpd: free():
invalid next
> size (fast): 0x087bdf40 ***
> ======= Backtrace: =========
> /lib/tls/i686/cmov/libc.so.6[0xb7d7b7cd]
> /lib/tls/i686/cmov/libc.so.6(cfree+0x90)[0xb7d7ee30]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msFreeShape+0x35)[0x
> b7814de5]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawVectorLayer+0x
> 336)[0xb7828ca6]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawLayer+0xaa)[0x
> b7828faa]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawMap+0x5d3)[0xb
> 7829f33]
/usr/local/apache229/php/extensions/php_mapscript_44.so(mapObj_draw+0x1d)[0x
> b77e34dd]
/usr/local/apache229/php/extensions/php_mapscript_44.so(php3_ms_map_draw+0x6
> c)[0xb77db65c]
> /usr/local/apache229/modules/libphp4.so(execute+0x6b43)[0xb7c7d943]
/usr/local/apache229/modules/libphp4.so(zend_execute_scripts+0xde)[0xb7c674f
> e]
/usr/local/apache229/modules/libphp4.so(php_execute_script+0x316)[0xb7c3b006
> /usr/local/apache229/modules/libphp4.so[0xb7c8171b]
> /usr/local/apache229/bin/httpd(ap_run_handler+0x59)[0x807b1b9]
> /usr/local/apache229/bin/httpd(ap_invoke_handler+0x67)[0x807e447]
> /usr/local/apache229/bin/httpd(ap_process_request+0x178)[0x8098af8]
> /usr/local/apache229/bin/httpd[0x8095d9b]
/usr/local/apache229/bin/httpd(ap_run_process_connection+0x59)[0x8082539]
> /usr/local/apache229/bin/httpd[0x80b68f5]
> /usr/local/apache229/bin/httpd[0x80b6bb7]
> /usr/local/apache229/bin/httpd(ap_mpm_run+0x880)[0x80b7510]
> /usr/local/apache229/bin/httpd(main+0x865)[0x8068ae5]
> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xdc)[0xb7d29ebc]
/usr/local/apache229/bin/httpd(apr_os_proc_mutex_put+0x5d)[0x8067ca1]
--http://www.provincia.biella.it------------------------------------------------------
> Vuoi rimanere sempre aggiornato sulle nostre attivita'?
> Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla
sezione di
> interesse.
--Avviso------------------------------------------------------------------------------
> Questo messaggio e i suoi allegati sono riservati esclusivamente
alle
> persone in
> indirizzo e possono contenere informazioni confidenziali. Se questo
> messaggio vi e'
> pervenuto per errore, vi informiamo che ogni suo uso e'proibito.
> In questo caso rispedite immediatamente il messaggio al mittente
e
> cancellatelo.
> Per ogni chiarimento contattateci scrivendo a
ced at provincia.biella.it.
> Grazie -Il Webmaster.
--Warning-----------------------------------------------------------------------------
> This message and its attachments are addressed solely to the persons
above
> and may
> contain confidential information. If you have received the message in
error,
> be
> informed that any use of the content hereof is prohibited.
> Please return it immediately to the sender and delete the message.
Should
> you have
> any questions, please contact us by replying to
> The Webmaster.
