R: [mapserver-users] Apache crash using Mapserver with big mapfile(about 2500 lines)
Edgardo Ghibaudo edgardo.ghibaudo at provincia.biella.it
Fri May 8 03:57:00 EDT 2009
Thank you Steve.
Launching shp2img I obtain the following error:
  ./shp2img -m /opt/fgs/apps/mapservergeo/map/at7_2_3.map
*** glibc detected *** malloc(): memory corruption: 0x08467628 ***
Aborted
Edgardo
-----Messaggio originale-----
Da: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Inviato: giovedì 7 maggio 2009 19.29
A: 'mapserver-users at lists.osgeo.org'; Edgardo Ghibaudo
Oggetto: Re: [mapserver-users] Apache crash using Mapserver with big mapfile(about 2500 lines)
Have you tried running through shp2img independently of MapLab to see if
it's a problem with MapServer or
MapLab specifically?
Steve
>>> On 5/7/2009 at 4:31 AM, in message
<a3fc4ad4.1c9cef6.23e1ca.29 at provincia.biella.it>, Edgardo Ghibaudo
<edgardo.ghibaudo at provincia.biella.it> wrote:
> Dear users,
> I'm using the following environment:
> Ubuntu 6.06 (libc6 2.3.6)
> Apache 2.2.9
> Php 4.4.2
> Mapserver 4.8.2
> Maplab 2.2.1 (last available version)
> Using a project inside Maplab/gmapfactory with a big mapfile (about
2500
> lines) the httpd process of Apache crash.
> Enclosed you can find the details of the crash (Backtrace).
> Apache compilation details:
> ./configure --prefix=/usr/local/apache229 --enable-info
--enable-mime-magic
> --enable-rewrite --enable-so --enable-speling --enable-unique_id
--enable-usertrack
> --with-mpm=prefork
> PHP compilation details:
> ./configure --enable-kbmmw --with-regex=system --with-freetype
--with-dbase
> --prefix=/usr/local/apache229/php --with-mysql=/usr/local/mysql4115
> --with-pgsql=shared,/usr/local/pgsql8014
> --with-pdflib=shared,/usr/local/pdflite703
> --with-config-file-path=/usr/local/apache229/php --with-png
--with-jpeg
> --with-jpeg-dir=/usr/local --with-tiff --with-gd --with-zlib
--enable-track-vars
> --enable-sockets --enable-wddx=shared --with-xmlrpc=shared
--enable-calendar
> --with-iconv=/usr/local/libiconv112
--with-iconv-dir=/usr/local/libiconv112
> --with-apxs2=/usr/local/apache229/bin/apxs --enable-cgi
> Mapserver compilation details:
> ./configure --enable-debug --with-proj=/usr/local
> --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config
> --with-gd --with-httpd=/usr/local/apache229/bin/httpd
> --with-php=/usr/local/apache229/php
> --with-php-regex-dir=/usr/local/apache229/php/regex --enable-runpath
> --enable-force-freetype1 --with-wmsclient --with-freetype
--with-png=/usr/local
> --with-jpeg=/usr/local --with-libiconv=/usr/local --with-wfs
--with-wfsclient
> --with-postgis=/usr/local/pgsql8014/bin/pg_config
> I tried to upgrade the OS version (Ubuntu 7.04 - libc6 2.5.0), but
the
> result doesn't change.
> I tried also to compile different SW versions (Apache 1.3.41, Php
4.4.9,
> Mapserver 4.8.3 & 4.8.4), but the result doesn't change
> Many thanks,
> Edgardo
> *** glibc detected *** /usr/local/apache229/bin/httpd: free():
invalid next
> size (fast): 0x087bdf40 ***
> ======= Backtrace: =========
> /lib/tls/i686/cmov/libc.so.6[0xb7d7b7cd]
> /lib/tls/i686/cmov/libc.so.6(cfree+0x90)[0xb7d7ee30]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msFreeShape+0x35)[0x
> b7814de5]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawVectorLayer+0x
> 336)[0xb7828ca6]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawLayer+0xaa)[0x
> b7828faa]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawMap+0x5d3)[0xb
> 7829f33]
/usr/local/apache229/php/extensions/php_mapscript_44.so(mapObj_draw+0x1d)[0x
> b77e34dd]
/usr/local/apache229/php/extensions/php_mapscript_44.so(php3_ms_map_draw+0x6
> c)[0xb77db65c]
> /usr/local/apache229/modules/libphp4.so(execute+0x6b43)[0xb7c7d943]
/usr/local/apache229/modules/libphp4.so(zend_execute_scripts+0xde)[0xb7c674f
> e]
/usr/local/apache229/modules/libphp4.so(php_execute_script+0x316)[0xb7c3b006
> /usr/local/apache229/modules/libphp4.so[0xb7c8171b]
> /usr/local/apache229/bin/httpd(ap_run_handler+0x59)[0x807b1b9]
> /usr/local/apache229/bin/httpd(ap_invoke_handler+0x67)[0x807e447]
> /usr/local/apache229/bin/httpd(ap_process_request+0x178)[0x8098af8]
> /usr/local/apache229/bin/httpd[0x8095d9b]
/usr/local/apache229/bin/httpd(ap_run_process_connection+0x59)[0x8082539]
> /usr/local/apache229/bin/httpd[0x80b68f5]
> /usr/local/apache229/bin/httpd[0x80b6bb7]
> /usr/local/apache229/bin/httpd(ap_mpm_run+0x880)[0x80b7510]
> /usr/local/apache229/bin/httpd(main+0x865)[0x8068ae5]
> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xdc)[0xb7d29ebc]
/usr/local/apache229/bin/httpd(apr_os_proc_mutex_put+0x5d)[0x8067ca1]
--http://www.provincia.biella.it------------------------------------------------------
> Vuoi rimanere sempre aggiornato sulle nostre attivita'?
> Visita la pagina dei feed RSS sul nostro sito ed  iscriviti alla
sezione di
> interesse.
--Avviso------------------------------------------------------------------------------
> Questo messaggio e i suoi allegati sono riservati esclusivamente
alle
> persone in
> indirizzo e possono contenere informazioni confidenziali. Se questo
> messaggio  vi  e'
> pervenuto per errore, vi informiamo  che ogni suo uso e'proibito.
> In  questo   caso  rispedite immediatamente il messaggio al mittente
e
> cancellatelo.
> Per ogni  chiarimento contattateci scrivendo  a
ced at provincia.biella.it.
> Grazie -Il Webmaster.
--Warning-----------------------------------------------------------------------------
> This message and its attachments are addressed solely to  the persons
above
> and may
> contain confidential information. If you have received the message in
error,
> be
> informed that any use of the content hereof is prohibited.
> Please return it  immediately  to the sender and  delete the message.
Should
> you have
> any questions, please  contact us by replying to
> The Webmaster.
Visita la pagina dei feed RSS sul nostro sito ed  iscriviti alla sezione di interesse.
Questo messaggio e i suoi allegati sono riservati esclusivamente  alle persone in
indirizzo e possono contenere informazioni confidenziali. Se questo  messaggio  vi  e'
In  questo   caso  rispedite immediatamente il messaggio al mittente e cancellatelo.
Per ogni  chiarimento contattateci scrivendo  a ced at provincia.biella.it.
This message and its attachments are addressed solely to  the persons above and may
contain confidential information. If you have received the message in error, be
Please return it  immediately  to the sender and  delete the message. Should you have
any questions, please  contact us by replying to ced at provincia.biella.it.
The Webmaster.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090508/3f913eb5/attachment-0001.html
