I: [mapserver-users] Apache crash using Mapserver with big
mapfile(about 2500 lines)
Edgardo Ghibaudo
edgardo.ghibaudo at provincia.biella.it
Fri May 8 04:50:00 EDT 2009
Steve,
I compiled mapserver with -enable-debug option.
Then I re-launched shp2img in the following way:
./shp2img -all_debug 5 -m /opt/fgs/apps/mapservergeo/map/at7_2_3.map
[Fri May 8 10:45:49 2009].96896 msDrawRasterLayerLow(Sfumo): entering.
[Fri May 8 10:45:49 2009].105123 msDrawGDAL(): src=704,474,913,1009, dst=0,0,470,520
[Fri May 8 10:45:49 2009].105479 msDrawGDAL(): red,green,blue,alpha bands = 1,2,3,0
[Fri May 8 10:45:49 2009].277761 msDrawMap(): Layer 0 (Sfumo), 0.181s
[Fri May 8 10:45:49 2009].288732 msDrawMap(): Layer 7 (Edificato), 0.011s
*** glibc detected *** free(): invalid next size (fast): 0x0846d138 ***
Aborted
Edgardo
Da: Edgardo Ghibaudo [mailto:edgardo.ghibaudo at provincia.biella.it]
Inviato: venerdì 8 maggio 2009 9.57
A: 'Steve Lime'; 'mapserver-users at lists.osgeo.org'
Oggetto: R: [mapserver-users] Apache crash using Mapserver with big mapfile(about 2500 lines)
Thank you Steve.
Launching shp2img I obtain the following error:
./shp2img -m /opt/fgs/apps/mapservergeo/map/at7_2_3.map
*** glibc detected *** malloc(): memory corruption: 0x08467628 ***
Aborted
Edgardo
-----Messaggio originale-----
Da: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Inviato: giovedì 7 maggio 2009 19.29
A: 'mapserver-users at lists.osgeo.org'; Edgardo Ghibaudo
Oggetto: Re: [mapserver-users] Apache crash using Mapserver with big mapfile(about 2500 lines)
Have you tried running through shp2img independently of MapLab to see if
it's a problem with MapServer or
MapLab specifically?
Steve
>>> On 5/7/2009 at 4:31 AM, in message
<a3fc4ad4.1c9cef6.23e1ca.29 at provincia.biella.it>, Edgardo Ghibaudo
<edgardo.ghibaudo at provincia.biella.it> wrote:
> Dear users,
> I'm using the following environment:
> Ubuntu 6.06 (libc6 2.3.6)
> Apache 2.2.9
> Php 4.4.2
> Mapserver 4.8.2
> Maplab 2.2.1 (last available version)
> Using a project inside Maplab/gmapfactory with a big mapfile (about
2500
> lines) the httpd process of Apache crash.
> Enclosed you can find the details of the crash (Backtrace).
> Apache compilation details:
> ./configure --prefix=/usr/local/apache229 --enable-info
--enable-mime-magic
> --enable-rewrite --enable-so --enable-speling --enable-unique_id
--enable-usertrack
> --with-mpm=prefork
> PHP compilation details:
> ./configure --enable-kbmmw --with-regex=system --with-freetype
--with-dbase
> --prefix=/usr/local/apache229/php --with-mysql=/usr/local/mysql4115
> --with-pgsql=shared,/usr/local/pgsql8014
> --with-pdflib=shared,/usr/local/pdflite703
> --with-config-file-path=/usr/local/apache229/php --with-png
--with-jpeg
> --with-jpeg-dir=/usr/local --with-tiff --with-gd --with-zlib
--enable-track-vars
> --enable-sockets --enable-wddx=shared --with-xmlrpc=shared
--enable-calendar
> --with-iconv=/usr/local/libiconv112
--with-iconv-dir=/usr/local/libiconv112
> --with-apxs2=/usr/local/apache229/bin/apxs --enable-cgi
> Mapserver compilation details:
> ./configure --enable-debug --with-proj=/usr/local
> --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config
> --with-gd --with-httpd=/usr/local/apache229/bin/httpd
> --with-php=/usr/local/apache229/php
> --with-php-regex-dir=/usr/local/apache229/php/regex --enable-runpath
> --enable-force-freetype1 --with-wmsclient --with-freetype
--with-png=/usr/local
> --with-jpeg=/usr/local --with-libiconv=/usr/local --with-wfs
--with-wfsclient
> --with-postgis=/usr/local/pgsql8014/bin/pg_config
> I tried to upgrade the OS version (Ubuntu 7.04 - libc6 2.5.0), but
the
> result doesn't change.
> I tried also to compile different SW versions (Apache 1.3.41, Php
4.4.9,
> Mapserver 4.8.3 & 4.8.4), but the result doesn't change
> Many thanks,
> Edgardo
> *** glibc detected *** /usr/local/apache229/bin/httpd: free():
invalid next
> size (fast): 0x087bdf40 ***
> ======= Backtrace: =========
> /lib/tls/i686/cmov/libc.so.6[0xb7d7b7cd]
> /lib/tls/i686/cmov/libc.so.6(cfree+0x90)[0xb7d7ee30]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msFreeShape+0x35)[0x
> b7814de5]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawVectorLayer+0x
> 336)[0xb7828ca6]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawLayer+0xaa)[0x
> b7828faa]
/usr/local/apache229/php/extensions/php_mapscript_44.so(msDrawMap+0x5d3)[0xb
> 7829f33]
/usr/local/apache229/php/extensions/php_mapscript_44.so(mapObj_draw+0x1d)[0x
> b77e34dd]
/usr/local/apache229/php/extensions/php_mapscript_44.so(php3_ms_map_draw+0x6
> c)[0xb77db65c]
> /usr/local/apache229/modules/libphp4.so(execute+0x6b43)[0xb7c7d943]
/usr/local/apache229/modules/libphp4.so(zend_execute_scripts+0xde)[0xb7c674f
> e]
/usr/local/apache229/modules/libphp4.so(php_execute_script+0x316)[0xb7c3b006
> /usr/local/apache229/modules/libphp4.so[0xb7c8171b]
> /usr/local/apache229/bin/httpd(ap_run_handler+0x59)[0x807b1b9]
> /usr/local/apache229/bin/httpd(ap_invoke_handler+0x67)[0x807e447]
> /usr/local/apache229/bin/httpd(ap_process_request+0x178)[0x8098af8]
> /usr/local/apache229/bin/httpd[0x8095d9b]
/usr/local/apache229/bin/httpd(ap_run_process_connection+0x59)[0x8082539]
> /usr/local/apache229/bin/httpd[0x80b68f5]
> /usr/local/apache229/bin/httpd[0x80b6bb7]
> /usr/local/apache229/bin/httpd(ap_mpm_run+0x880)[0x80b7510]
> /usr/local/apache229/bin/httpd(main+0x865)[0x8068ae5]
> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xdc)[0xb7d29ebc]
/usr/local/apache229/bin/httpd(apr_os_proc_mutex_put+0x5d)[0x8067ca1]
--http://www.provincia.biella.it------------------------------------------------------
> Vuoi rimanere sempre aggiornato sulle nostre attivita'?
> Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla
sezione di
> interesse.
--Avviso------------------------------------------------------------------------------
> Questo messaggio e i suoi allegati sono riservati esclusivamente
alle
> persone in
> indirizzo e possono contenere informazioni confidenziali. Se questo
> messaggio vi e'
> pervenuto per errore, vi informiamo che ogni suo uso e'proibito.
> In questo caso rispedite immediatamente il messaggio al mittente
e
> cancellatelo.
> Per ogni chiarimento contattateci scrivendo a
ced at provincia.biella.it.
> Grazie -Il Webmaster.
--Warning-----------------------------------------------------------------------------
> This message and its attachments are addressed solely to the persons
above
> and may
> contain confidential information. If you have received the message in
error,
> be
> informed that any use of the content hereof is prohibited.
> Please return it immediately to the sender and delete the message.
Should
> you have
> any questions, please contact us by replying to
> The Webmaster.
Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla sezione di interesse.
Questo messaggio e i suoi allegati sono riservati esclusivamente alle persone in
indirizzo e possono contenere informazioni confidenziali. Se questo messaggio vi e'
In questo caso rispedite immediatamente il messaggio al mittente e cancellatelo.
Per ogni chiarimento contattateci scrivendo a ced at provincia.biella.it.
This message and its attachments are addressed solely to the persons above and may
contain confidential information. If you have received the message in error, be
Please return it immediately to the sender and delete the message. Should you have
any questions, please contact us by replying to ced at provincia.biella.it.
The Webmaster.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090508/946dab2b/attachment-0001.html
