[mapserver-users] problem in reference map
Ahmet Temiz temiz at deprem.gov.tr
Fri May 8 13:25:29 EDT 2009
Thank you
I am using java. However, I try to adapt C# to java
On Fri, 8 May 2009 12:46:09 +0530, Venkat Rao Tammineni wrote
> HI,
>   Which language you are using ...if it is C# , then I can help you.
> Thanks
> Venkat
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ahmet Temiz
> Sent: Friday, May 08, 2009 12:39 PM
> To: Steve Lime; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] problem in reference map
> On Thu, 07 May 2009 12:26:47 -0500, Steve Lime wrote
> thank you
> reference map extent is same as main map extent.
> I checked size of reference map.
> But the problem still exists.
> > Most likely your reference map size or extent are incorrect. That's
> > where I'd start.
> > Steve
> > >>> On 5/7/2009 at 6:54 AM, in message
> <20090507115038.M79754 at deprem.gov.tr>,
> > "Ahmet Temiz" <temiz at deprem.gov.tr> wrote:
> > > hello
> > > the red box in my reference map isn't settled on my zoomed main map.
> > > what am I likely to miss ?
> > > regards
> > > Ahmet Temiz
> > > Open WebMail Project (http://openwebmail.org)
> > This message has been scanned for viruses and
> > dangerous content by MailScanner, and is
> > believed to be clean.
