[mapserver-users] Apache crash using Mapserver with bigmapfile(about 2500 lines)
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Sun May 10 02:55:36 EDT 2009
I thought there were links of MapServer based application fraworks on MapServer web pages, but I cannot find it now.  Anyway, MS4W download page has some easy-to-install modules for GeoMOOSE, MapBender, p.mapper etc.  I fear none of them is as simple to use for a beginner as MapLab was.  There are for sure more alternatives, also commersial like Neapolis (http://www.mapserver.ch/en/index.html) that is quite easy and nice to use. Others can add to my list.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Edgardo Ghibaudo
Lähetetty: pe 8.5.2009 13:44
Vastaanottaja: 'Steve Lime'; 'mapserver-users at lists.osgeo.org'
Aihe: I: [mapserver-users] Apache crash using Mapserver with bigmapfile(about 2500 lines)
Steve,
Using shp2img we understood the reason of the crash.
Thank you for your support.
We are using Maplab 2.2.1 (the last version available - dated 29/09/2005). This product will constrain us to use Mapserver 4.8.x.
The next versions of Mapserver (4.10.x & 5.x.x) doesn't work with Maplab.
Do you know some alternative SW for Maplab ?
Thanks in advance, Edgardo
Da: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Per conto di Edgardo Ghibaudo
Inviato: venerdì 8 maggio 2009 10.53
A: 'Steve Lime'; 'mapserver-users at lists.osgeo.org'
Oggetto: I: [mapserver-users] Apache crash using Mapserver with big mapfile(about 2500 lines)
Steve,
I compiled mapserver with -enable-debug option.
Then I launched shp2img in the following way:
./shp2img -all_debug 5 -m /opt/fgs/apps/mapservergeo/map/at7_2_3.map
[Fri May  8 10:45:49 2009].96896 msDrawRasterLayerLow(Sfumo): entering.
[Fri May  8 10:45:49 2009].105123 msDrawGDAL(): src=704,474,913,1009, dst=0,0,470,520
[Fri May  8 10:45:49 2009].105479 msDrawGDAL(): red,green,blue,alpha bands = 1,2,3,0
[Fri May  8 10:45:49 2009].277761 msDrawMap(): Layer 0 (Sfumo), 0.181s
[Fri May  8 10:45:49 2009].288732 msDrawMap(): Layer 7 (Edificato), 0.011s
*** glibc detected *** free(): invalid next size (fast): 0x0846d138 ***
Aborted
Edgardo
-----Messaggio originale-----
Da: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Inviato: giovedì 7 maggio 2009 19.29
A: 'mapserver-users at lists.osgeo.org'; Edgardo Ghibaudo
Oggetto: Re: [mapserver-users] Apache crash using Mapserver with big mapfile(about 2500 lines)
Have you tried running through shp2img independently of MapLab to see if
it's a problem with MapServer or
MapLab specifically?
Steve
--http://www.provincia.biella.it------------------------------------------------------
Vuoi rimanere sempre aggiornato sulle nostre attivita'?
Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla sezione di interesse.
--Avviso------------------------------------------------------------------------------
Questo messaggio e i suoi allegati sono riservati esclusivamente alle persone in
indirizzo e possono contenere informazioni confidenziali. Se questo messaggio vi e'
pervenuto per errore, vi informiamo che ogni suo uso e'proibito.
In questo caso rispedite immediatamente il messaggio al mittente e cancellatelo.
Per ogni chiarimento contattateci scrivendo a ced at provincia.biella.it.
Grazie -Il Webmaster.
--Warning-----------------------------------------------------------------------------
This message and its attachments are addressed solely to the persons above and may
contain confidential information. If you have received the message in error, be
informed that any use of the content hereof is prohibited.
Please return it immediately to the sender and delete the message. Should you have
any questions, please contact us by replying to ced at provincia.biella.it.
The Webmaster.
The Webmaster.
