[mapserver-users] Check layer status in Geomoose
Dan Little
danlittle at yahoo.com
Wed May 13 23:08:01 EDT 2009
GeoMOOSE 1.6.X (and 2.0) suffer some documentation difficulties... it's a "learn by example" setup right now. We're trying to get better with GM2.0 and its documentation is arguably better (http://www.geomoose.org/geomoose2/docs/) than GM1.6 but I still need to do more work documenting the different input options.
----- Original Message ----
> From: Leonidas Liakos <leonidas_liakos at yahoo.gr>
> To: mapserver-users at lists.osgeo.org; Dan Little <danlittle at yahoo.com>
> Sent: Tuesday, May 12, 2009 1:08:54 PM
> Subject: Re: [mapserver-users] Check layer status in Geomoose
> Thank you, I found it just looking at default identify tool.Is that option
> documented?
> --- Στις Τρίτ., 12/05/09, ο/η Dan Little έγραψε:
> > Από: Dan Little
> > Θέμα: Re: [mapserver-users] Check layer status in Geomoose
> > Προς: "leonidas" , mapserver-users at lists.osgeo.org
> > Ημερομηνία: Τρίτη, 12 Μάιος 2009, 19:59
> > You need to have an input type that sends the visiblelayers
> > input to your script.
> > Are you using GeoMOOSE 1.6.X or GeoMOOSE 2.0 beta?
> > > From: leonidas
> > > Sent: Monday, May 11, 2009 8:00:03 AM
> > > Subject: [mapserver-users] Check layer status in
> > Geomoose
> > > I'm writing a custom tool in geomoose based on
> > php/mapscript.
> > > I'm trying to get the layer status for each on of
> > my layers using
> > > $qlayer->status property.
> > > Always and for each layer it returns the value 2. But
> > there aren't all the
> > > layers checked in the treeview of geomoose (and
> > according displayed in the
> > > map). I think that $qlayer->status property always
> > return 2 because it
> > > checks the status in the mapfile (for my layers the
> > status is DEFAULT) and
> > > not what is displayed in the map. So how can I get
> > only the layers that are
> > > displayed in the map (or are checked in the treeview
> > of Geomoose)? I also
> > > checked the $qlayer->isVisible() property but it
> > also works with the same
> > > logic (it returns 1 for all layers, displayed or
> > not).Thank you.
> > > View this message in context:
> > http://n2.nabble.com/Check-layer-status-in-Geomoose-tp2862814p2862814.html
> > > Sent from the Mapserver - User mailing list archive at
> > Nabble.com.
> > > _______________________________________________
> > > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> ___________________________________________________________
> Χρησιμοποιείτε Yahoo!;
> Βαρεθήκατε τα ενοχλητικά μηνύματα (spam); Το Yahoo! Mail
> διαθέτει την καλύτερη δυνατή προστασία κατά των ενοχλητικών
> μηνυμάτων http://login.yahoo.com/config/mail?.intl=gr
