[mapserver-users] queryByAttributes returns no result with
OGR/ODBC data source
Dejan.Gambin at pula.hr
Mon May 18 02:19:07 EDT 2009
Unfortunatelly it doesn't help. I have tried with:
queryByAttributes("[KOORDINATAX]", ( [KOORDINATAX] = 5460870 ),
MS_MULTIPLE);
and with
queryByAttributes("[KOORDINATAX]", 5460870, MS_MULTIPLE);
Neither one gives results :-(
dejan
Maher Karim <Maher_Karim at dorsch.com.jo> wrote on 18.05.2009 07:28:19:
> HI,
> Please consider that there is a difference the field name definintion
for
> the item query, the field name is differenet when you are using
shapefiles
> than PostGIS tables.
> Try to use
> $strExp=( [KOORDINATAX] = 5460870 );
> queryByAttributes('itemname',$strExp,MS_MULTIPLE)
> and if Not working try
> queryByAttributes( [KOORDINATAX],5460870,MS_MULTIPLE)
> Hope that it helps
> Regards
> Maher
> | | Dejan.Gambin at pula.hr |
> | | Sent by: |
> | | mapserver-users-bounces at list|
> | | s.osgeo.org |
> | | 05/18/2009 12:50 AM |
> | To: mapserver-users at lists.osgeo.org |
> | cc: |
> | Subject: [mapserver-users] queryByAttributes returns no
> result with OGR/ODBC data source |
> Hi,
> I am using OGR Virtual Spatial Data to connect to MS Access database
using
> ODBC. Database has X/Y columns. I have created .ovf file like this:
> <OGRVRTDataSource>
> <OGRVRTLayer name="krk">
> <SrcDataSource>ODBC:@Krk</SrcDataSource>
> <FID>ID</FID>
> <SrcLayer>Dozvole</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="KoordinataX"
> y="KoordinataY"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> It is all working fine and the points are showing on the map (using
> p.mapper). Alos, ogrinfo with -where clause is working fine. But the
> attribute query gives no result, whichever field I query. Query string
is
> like:
> This syntax works fine with shape files and also wit OGR layers based on
> MapInfo files. But not with ODBC/Access.
> I am using ms4w 2.2.7
> Any help?
> regards, dejan_______________________________________________
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090518/fba132f2/attachment.html
