[mapserver-users] PERL MapScript
Kralidis,Tom [Ontario]
Tom.Kralidis at ec.gc.ca
Tue May 19 19:57:42 EDT 2009
I get the same error when running mapObj->get("name"). I don't see any get() method in mapObj. From my example, you should see a out2.xml file written to disk.
..Tom
-----Original Message-----
From: Christopher Condit [mailto:condit at sdsc.edu]
Sent: Tue 19-May-09 19:45
To: Kralidis,Tom [Ontario]; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] PERL MapScript
Hi Tom-
> What does your code look like? The following works for me:
#!/usr/bin/perl
use mapscript;
use strict;
my $map = new mapscript::mapObj("test.map") or die "no map $!";
my $name = $map->get("name");
print $name;
> #!/usr/bin/perl
> use strict;
> use warnings;
> use mapscript;
> my $map = new mapscript::mapObj('test.map');
> $map->saveMapContext('out2.xml');
I also tried running your code. It doesn't generate an error but no
test.xml file is created...
Any thoughts?
Thanks,
-Chris
