[mapserver-users] MapServer 5.4.0 Buffer Overflow Error
Juan Felipe Alvarez Saldarriaga
jfalvarez at vesifront.org
Wed May 20 07:56:23 EDT 2009
Thx Umberto, I'll try to reinstall GDAL then, thx :).
On Wed, May 20, 2009 at 12:39 AM, Umberto Nicoletti
<umberto.nicoletti at gmail.com> wrote:
> This is a known issue with recent Ubuntu systems which is caused by a
> special compiler feature (called fortify) which enables a protection
> system against the most common memory management errors. Unfortunately
> as a result of this GDAL will break and dependent sw become unusable
> (mapserver, grass, qgis, etc).
> Luckily there is a workaround: remove the gdal installed by canonical
> and install the packages from ubuntu gis project instead:
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
> You may have to recompile mapserver after this.
> Happy hacking,
> Umberto
> On Wed, May 20, 2009 at 5:18 AM, Juan Felipe Alvarez Saldarriaga
> <jfalvarez at vesifront.org> wrote:
>> Hey!.
>> I'm trying to load a WMS layer, but I got always a buffer overflow
>> error, thx for any advice! :)
>> This is my mapserv config:
>> root at vesifront:/usr/lib/cgi-bin# ./mapserv -v
>> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
>> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS
>> _CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE
>> My system is a Ubuntu Linux 9.04 and this is the WMS layer into the map file:
>> LAYER
>> NAME 'Mapa Base'
>> TYPE RASTER
>> CONNECTIONTYPE WMS
>> CONNECTION "http://wms.jpl.nasa.gov/browse.cgi?wms_server=wms.cgi"
>> METADATA
>> 'wms_server_version' '1.1.1'
>> 'wms_format' 'image/jpeg'
>> 'wms_style' ''
>> 'wms_name' 'BMNG'
>> END
>> METADATA
>> # 'wms_title' 'Mapa Base'
>> 'wms_title' 'BMNG'
>> END
>> STATUS DEFAULT
>> TRANSPARENCY 100
>> PROJECTION
>> "init=epsg:4326"
>> END
>> END
>> And this is the error that I got when I try to test the map file with shp2img:
>> root at vesifront:/usr/lib/cgi-bin# shp2img -all_debug 3 -m /home/jfalvarez/projec
>> ts/cms/branches/V1/docroot/map-files/9182340517c2d323061dc1cffea6e431.map -o ou
>> [Tue May 19 22:14:03 2009].813526 msLoadMap(): 0.006s
>> [Tue May 19 22:14:03 2009].816973 HTTP: Starting to prepare HTTP requests.
>> [Tue May 19 22:14:03 2009].817552 HTTP request: id=0, http://wms.jpl.nasa.gov/br
>> owse.cgi?wms_server=wms.cgi&LAYERS=BMNG&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/
>> jpeg&STYLES=&HEIGHT=600&VERSION=1.1.1&SRS=EPSG:4326&WIDTH=800&BBOX=-94.076794657
>> 7629,-54.0575959933222,-1.92320534223706,15.0575959933222&TRANSPARENT=TRUE&EXCEP
>> TIONS=application/vnd.ogc.se_inimage
>> [Tue May 19 22:14:03 2009].819297 HTTP: Before download loop
>> [Tue May 19 22:14:04 2009].175669 msHTTPWriteFct(id=0, 852 bytes)
>> [Tue May 19 22:14:04 2009].279581 HTTP: After download loop
>> [Tue May 19 22:14:04 2009].280033 msHTTPExecuteRequests() timing summary per lay
>> er (connect_time + time_to_first_packet + download_time = total_time in seconds)
>> [Tue May 19 22:14:04 2009].280572 Layer 0: 0.169 + 0.186 + 0.274 = 0.629s
>> [Tue May 19 22:14:04 2009].281375 msDrawRasterLayerLow(BMNG): entering.
>> *** buffer overflow detected ***: shp2img terminated
>> ======= Backtrace: =========
>> /lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb6a87da8]
>> /lib/tls/i686/cmov/libc.so.6[0xb6a85eb0]
>> /lib/tls/i686/cmov/libc.so.6(__strcpy_chk+0x44)[0xb6a85184]
>> shp2img(msDrawRasterLayerLow+0x91d)[0x80c4e0d]
>> shp2img(msDrawRasterLayer+0x7b)[0x807ffab]
>> shp2img(msDrawLayer+0x35e)[0x8080f0e]
>> shp2img(msDrawWMSLayerLow+0x598)[0x80d57d8]
>> shp2img(msDrawMap+0x834)[0x8082794]
>> shp2img(main+0x912)[0x8059722]
>> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb69a0775]
>> shp2img[0x8058d71]
>> ======= Memory map: ========
>> 08048000-08110000 r-xp 00000000 fd:00 197813 /usr/local/bin/shp2img
>> 08110000-08111000 r--p 000c7000 fd:00 197813 /usr/local/bin/shp2img
>> 08111000-08114000 rw-p 000c8000 fd:00 197813 /usr/local/bin/shp2img
>> 08114000-08222000 rw-p 08114000 00:00 0 [heap]
>> b588c000-b5891000 r-xp 00000000 fd:00 98403 /lib/tls/i686/cmov/libnss_dns-2
>> .9.so
>> b5891000-b5892000 r--p 00004000 fd:00 98403 /lib/tls/i686/cmov/libnss_dns-2
>> .9.so
>> b5892000-b5893000 rw-p 00005000 fd:00 98403 /lib/tls/i686/cmov/libnss_dns-2
>> .9.so
>> b5893000-b589d000 r-xp 00000000 fd:00 98405 /lib/tls/i686/cmov/libnss_files
>> -2.9.so
>> b589d000-b589e000 r--p 00009000 fd:00 98405 /lib/tls/i686/cmov/libnss_files
>> -2.9.so
>> b589e000-b589f000 rw-p 0000a000 fd:00 98405 /lib/tls/i686/cmov/libnss_files
>> -2.9.so
>> b589f000-b58a3000 rw-p b589f000 00:00 0
>> b58a3000-b58a6000 r-xp 00000000 fd:00 49415 /lib/libgpg-error.so.0.3.0
>> b58a6000-b58a7000 rw-p 00002000 fd:00 49415 /lib/libgpg-error.so.0.3.0
>> b58a7000-b58ab000 r-xp 00000000 fd:00 199058 /usr/lib/libXdmcp.so.6.0.0
>> b58ab000-b58ac000 rw-p 00003000 fd:00 199058 /usr/lib/libXdmcp.so.6.0.0
>> b58ac000-b58ae000 r-xp 00000000 fd:00 197736 /usr/lib/libXau.so.6.0.0
>> b58ae000-b58af000 r--p 00001000 fd:00 197736 /usr/lib/libXau.so.6.0.0
>> b58af000-b58b0000 rw-p 00002000 fd:00 197736 /usr/lib/libXau.so.6.0.0
>> b58b0000-b58c5000 r-xp 00000000 fd:00 98398 /lib/tls/i686/cmov/libnsl-2.9.s
>> o
>> b58c5000-b58c6000 r--p 00014000 fd:00 98398 /lib/tls/i686/cmov/libnsl-2.9.s
>> o
>> b58c6000-b58c7000 rw-p 00015000 fd:00 98398 /lib/tls/i686/cmov/libnsl-2.9.s
>> o
>> b58c7000-b58ca000 rw-p b58c7000 00:00 0
>> b58ca000-b58cc000 r-xp 00000000 fd:00 49292 /lib/libkeyutils-1.2.so
>> b58cc000-b58cd000 r--p 00001000 fd:00 49292 /lib/libkeyutils-1.2.so
>> b58cd000-b58ce000 rw-p 00002000 fd:00 49292 /lib/libkeyutils-1.2.so
>> b58ce000-b58d5000 r-xp 00000000 fd:00 198044 /usr/lib/libkrb5support.so.0.1
>> b58d5000-b58d6000 r--p 00006000 fd:00 198044 /usr/lib/libkrb5support.so.0.1
>> b58d6000-b58d7000 rw-p 00007000 fd:00 198044 /usr/lib/libkrb5support.so.0.1
>> b58d7000-b58f9000 r-xp 00000000 fd:00 197986 /usr/lib/libk5crypto.so.3.1
>> b58f9000-b58fa000 r--p 00022000 fd:00 197986 /usr/lib/libk5crypto.so.3.1
>> b58fa000-b58fb000 rw-p 00023000 fd:00 197986 /usr/lib/libk5crypto.so.3.1
>> b58fb000-b5911000 r-xp 00000000 fd:00 197574 /usr/lib/libsasl2.so.2.0.22
>> b5911000-b5912000 r--p 00015000 fd:00 197574 /usr/lib/libsasl2.so.2.0.22
>> b5912000-b5913000 rw-p 00016000 fd:00 197574 /usr/lib/libsasl2.so.2.0.22
>> b5913000-b5925000 r-xp 00000000 fd:00 98435 /lib/tls/i686/cmov/libresolv-2.
>> 9.so
>> b5925000-b5926000 r--p 00011000 fd:00 98435 /lib/tls/i686/cmov/libresolv-2.
>> 9.so
>> b5926000-b5927000 rw-p 00012000 fd:00 98435 /lib/tls/i686/cmov/libresolv-2.
>> 9.so
>> b5927000-b592a000 rw-p b5927000 00:00 0
>> b592a000-b5990000 r-xp 00000000 fd:00 49280 /lib/libgcrypt.so.11.4.4
>> b5990000-b5991000 r--p 00065000 fd:00 49280 /lib/libgcrypt.so.11.4.4
>> b5991000-b5993000 rw-p 00066000 fd:00 49280 /lib/libgcrypt.so.11.4.4
>> b5993000-b59a3000 r-xp 00000000 fd:00 196657 /usr/lib/libtasn1.so.3.0.16
>> b59a3000-b59a4000 r--p 0000f000 fd:00 196657 /usr/lib/libtasn1.so.3.0.16
>> b59a4000-b59a5000 rw-p 00010000 fd:00 196657 /usr/lib/libtasn1.so.3.0.16
>> b59a5000-b59ae000 r-xp 00000000 fd:00 98354 /lib/tls/i686/cmov/libcrypt-2.9
>> .so
>> b59ae000-b59af000 r--p 00008000 fd:00 98354 /lib/tls/i686/cmov/libcrypt-2.9
>> .so
>> b59af000-b59b0000 rw-p 00009000 fd:00 98354 /lib/tls/i686/cmov/libcrypt-2.9
>> .so
>> b59b0000-b59d7000 rw-p b59b0000 00:00 0
>> b59d7000-b59d9000 r-xp 00000000 fd:00 49185 /lib/libcom_err.so.2.1
>> b59d9000-b59da000 r--p 00001000 fd:00 49185 /lib/libcom_err.so.2.1
>> b59da000-b59db000 rw-p 00002000 fd:00 49185 /lib/libcom_err.so.2.1
>> b59db000-b5a6a000 r-xp 00000000 fd:00 197990 /usr/lib/libkrb5.so.3.3
>> b5a6a000-b5a6c000 r--p 0008e000 fd:00 197990 /usr/lib/libkrb5.so.3.3
>> b5a6c000-b5a6d000 rw-p 00090000 fd:00 197990 /usr/lib/libkrb5.so.3.3
>> b5a6d000-b5a6e000 rw-p b5a6d000 00:00 0
>> b5a6e000-b5ba1000 r-xp 00000000 fd:00 49509 /lib/i686/cmov/libcrypto.so.0.9
>> .8
>> b5ba1000-b5ba9000 r--p 00132000 fd:00 49509 /lib/i686/cmov/libcrypto.so.0.9
>> .8
>> b5ba9000-b5bb6000 rw-p 0013a000 fd:00 49509 /lib/i686/cmov/libcrypto.so.0.9
>> .8
>> b5bb6000-b5bba000 rw-p b5bb6000 00:00 0
>> b5bba000-b5bfc000 r-xp 00000000 fd:00 49512 /lib/i686/cmov/libssl.so.0.9.8
>> b5bfc000-b5bfd000 r--p 00041000 fd:00 49512 /lib/i686/cmov/libssl.so.0.9.8
>> b5bfd000-b5c00000 rw-p 00042000 fd:00 49512 /lib/i686/cmov/libssl.so.0.9.8
>> b5c00000-b66d6000 r--p 00000000 fd:00 198175 /usr/lib/libicudata.so.38.1
>> b66d6000-b66d7000 r--p 00ad5000 fd:00 198175 /usr/lib/libicudata.so.38.1
>> b66d7000-b67f4000 r-xp 00000000 fd:00 200522 /usr/lib/libicuuc.so.38.1
>> b67f4000-b67f5000 ---p 0011d000 fd:00 200522 /usr/lib/libicuuc.so.38.1
>> b67f5000-b67fd000 r--p 0011d000 fd:00 200522 /usr/lib/libicuuc.so.38.1
>> b67fd000-b67fe000 rw-p 00125000 fd:00 200522 /usr/lib/libicuuc.so.38.1
>> b67fe000-b6800000 rw-p b67fe000 00:00 0
>> b6800000-b6807000 r-xp 00000000 fd:00 197048 /usr/lib/libltdl.so.7.2.0
>> b6807000-b6808000 r--p 00006000 fd:00 197048 /usr/lib/libltdl.so.7.2.0
>> b6808000-b6809000 rw-p 00007000 fd:00 197048 /usr/lib/libltdl.so.7.2.0
>> b6809000-b680a000 rw-p b6809000 00:00 0
>> b680a000-b6930000 r-xp 00000000 fd:00 196683 /usr/lib/libgeos-3.0.0.so
>> b6930000-b6934000 rw-p 00125000 fd:00 196683 /usr/lib/libgeos-3.0.0.so
>> b6934000-b694c000 r-xp 00000000 fd:00 199065 /usr/lib/libxcb.so.1.1.0
>> b694c000-b694d000 r--p 00017000 fd:00 199065 /usr/lib/libxcb.so.1.1.0
>> b694d000-b694e000 rw-p 00018000 fd:00 199065 /usr/lib/libxcb.so.1.1.0
>> b694e000-b6979000 r-xp 00000000 fd:00 196744 /usr/lib/libfontconfig.so.1.3.0
>> b6979000-b697a000 r--p 0002a000 fd:00 196744 /usr/lib/libfontconfig.so.1.3.0
>> b697a000-b697b000 rw-p 0002b000 fd:00 196744 /usr/lib/libfontconfig.so.1.3.0
>> b697b000-b6988000 r-xp 00000000 fd:00 49222 /lib/libgcc_s.so.1
>> b6988000-b6989000 r--p 0000c000 fd:00 49222 /lib/libgcc_s.so.1
>> b6989000-b698a000 rw-p 0000d000 fd:00 49222 /lib/libgcc_s.so.1
>> b698a000-b6ae6000 r-xp 00000000 fd:00 98338 /lib/tls/i686/cmov/libc-2.9.so
>> b6ae6000-b6ae7000 ---p 0015c000 fd:00 98338 /lib/tls/i686/cmov/libc-2.9.so
>> b6ae7000-b6ae9000 r--p 0015c000 fd:00 98338 /lib/tls/i686/cmov/libc-2.9.so
>> b6ae9000-b6aea000 rw-p 0015e000 fd:00 98338 /lib/tls/i686/cmov/libc-2.9.so
>> b6aea000-b6aee000 rw-p b6aea000 00:00 0
>> b6aee000-b6bd2000 r-xp 00000000 fd:00 198979 /usr/lib/libstdc++.so.6.0.10
>> b6bd2000-b6bd6000 r--p 000e3000 fd:00 198979 /usr/lib/libstdc++.so.6.0.10
>> b6bd6000-b6bd7000 rw-p 000e7000 fd:00 198979 /usr/lib/libstdc++.so.6.0.10
>> b6bd7000-b6bdd000 rw-p b6bd7000 00:00 0
>> b6bdd000-b6c01000 r-xp 00000000 fd:00 98378 /lib/tls/i686/cmov/libm-2.9.so
>> b6c01000-b6c02000 r--p 00023000 fd:00 98378 /lib/tls/i686/cmov/libm-2.9.so
>> b6c02000-b6c03000 rw-p 00024000 fd:00 98378 /lib/tls/i686/cmov/libm-2.9.so
>> b6c03000-b6da2000 r-xp 00000000 fd:00 197497 /usr/lib/libmysqlclient.so.15.0
>> .0
>> b6da2000-b6da5000 r--p 0019e000 fd:00 197497 /usr/lib/libmysqlclient.so.15.0
>> .0
>> b6da5000-b6de5000 rw-p 001a1000 fd:00 197497 /usr/lib/libmysqlclient.so.15.0
>> .0
>> b6de5000-b6de6000 rw-p b6de5000 00:00 0
>> b6de6000-b6e7d000 r-xp 00000000 fd:00 201145 /usr/lib/libgnutls.so.26.4.6
>> b6e7d000-b6e82000 r--p 00097000 fd:00 201145 /usr/lib/libgnutls.so.26.4.6
>> b6e82000-b6e83000 rw-p 0009c000 fd:00 201145 /usr/lib/libgnutls.so.26.4.6
>> b6e83000-b6eac000 r-xp 00000000 fd:00 197192 /usr/lib/libgssapi_krb5.so.2.2
>> b6eac000-b6ead000 r--p 00028000 fd:00 197192 /usr/lib/libgssapi_krb5.so.2.2
>> b6ead000-b6eae000 rw-p 00029000 fd:00 197192 /usr/lib/libgssapi_krb5.so.2.2
>> b6eae000-b6eee000 r-xp 00000000 fd:00 198528 /usr/lib/libldap_r-2.4.so.2.4.1
>> b6eee000-b6eef000 ---p 00040000 fd:00 198528 /usr/lib/libldap_r-2.4.so.2.4.1
>> b6eef000-b6ef0000 r--p 00040000 fd:00 198528 /usr/lib/libldap_r-2.4.so.2.4.1
>> b6ef0000-b6ef1000 rw-p 00041000 fd:00 198528 /usr/lib/libldap_r-2.4.so.2.4.1
>> b6ef1000-b6ef3000 rw-p b6ef1000 00:00 0
>> b6ef3000-b6eff000 r-xp 00000000 fd:00 198526 /usr/lib/liblber-2.4.so.2.4.1
>> b6eff000-b6f00000 r--p 0000b000 fd:00 198526 /usr/lib/liblber-2.4.so.2.4.1
>> b6f00000-b6f01000 rw-p 0000c000 fd:00 198526 /usr/lib/liblber-2.4.so.2.4.1
>> b6f01000-b6f31000 r-xp 00000000 fd:00 197174 /usr/lib/libidn.so.11.5.39
>> b6f31000-b6f32000 ---p 00030000 fd:00 197174 /usr/lib/libidn.so.11.5.39
>> b6f32000-b6f33000 r--p 00030000 fd:00 197174 /usr/lib/libidn.so.11.5.39
>> b6f33000-b6f34000 rw-p 00031000 fd:00 197174 /usr/lib/libidn.so.11.5.39
>> b6f34000-b6f6d000 r-xp 00000000 fd:00 201911 /usr/lib/libcurl-gnutls.so.4.1.
>> 0
>> b6f6d000-b6f6e000 r--p 00038000 fd:00 201911 /usr/lib/libcurl-gnutls.so.4.1.
>> 0
>> b6f6e000-b6f6f000 rw-p 00039000 fd:00 201911 /usr/lib/libcurl-gnutls.so.4.1.
>> 0
>> b6f6f000-b6f71000 r-xp 00000000 fd:00 98374 /lib/tls/i686/cmov/libdl-2.9.so
>> b6f71000-b6f72000 r--p 00001000 fd:00 98374 /lib/tls/i686/cmov/libdl-2.9.so
>> b6f72000-b6f73000 rw-p 00002000 fd:00 98374 /lib/tls/i686/cmov/libdl-2.9.so
>> b6f73000-b6f7a000 r-xp 00000000 fd:00 98436 /lib/tls/i686/cmov/librt-2.9.so
>> b6f7a000-b6f7b000 r--p 00006000 fd:00 98436 /lib/tls/i686/cmov/librt-2.9.so
>> b6f7b000-b6f7c000 rw-p 00007000 fd:00 98436 /lib/tls/i686/cmov/librt-2.9.so
>> b6f7c000-b6f7d000 rw-p b6f7c000 00:00 0
>> b6f7d000-b6f9c000 r-xp 00000000 fd:00 198177 /usr/lib/libpq.so.5.1
>> b6f9c000-b6f9d000 r--p 0001e000 fd:00 198177 /usr/lib/libpq.so.5.1
>> b6f9d000-b6f9e000 rw-p 0001f000 fd:00 198177 /usr/lib/libpq.so.5.1
>> b6f9e000-b6fcd000 r-xp 00000000 fd:00 196821 /usr/lib/libnetcdf.so.4.0.0
>> b6fcd000-b6fce000 rw-p 0002e000 fd:00 196821 /usr/lib/libnetcdf.so.4.0.0
>> b6fce000-b6fcf000 rw-p b6fce000 00:00 0
>> b6fcf000-b6fd6000 r-xp 00000000 fd:00 199094 /usr/lib/libgif.so.4.1.6
>> b6fd6000-b6fd7000 r--p 00006000 fd:00 199094 /usr/lib/libgif.so.4.1.6
>> b6fd7000-b6fd8000 rw-p 00007000 fd:00 199094 /usr/lib/libgif.so.4.1.6
>> b6fd8000-b6ff4000 r-xp 00000000 fd:00 198859 /usr/lib/libogdi.so.3.2
>> b6ff4000-b6ff5000 r--p 0001b000 fd:00 198859 /usr/lib/libogdi.so.3.2
>> b6ff5000-b6ff6000 rw-p 0001c000 fd:00 198859 /usr/lib/libogdi.so.3.2
>> b6ff6000-b7072000 r-xp 00000000 fd:00 197865 /usr/lib/libdf.so.4.1r4
>> b7072000-b7073000 r--p 0007c000 fd:00 197865 /usr/lib/libdf.so.4.1r4
>> b7073000-b7075000 rw-p 0007d000 fd:00 197865 /usr/lib/libdf.so.4.1r4
>> b7075000-b709d000 rw-p b7075000 00:00 0
>> b709d000-b70bf000 r-xp 00000000 fd:00 197866 /usr/lib/libmfhdf.so.4.1r4
>> b70bf000-b70c0000 r--p 00021000 fd:00 197866 /usr/lib/libmfhdf.so.4.1r4
>> b70c0000-b70c1000 rw-p 00022000 fd:00 197866 /usr/lib/libmfhdf.so.4.1r4
>> b70c1000-b70c3000 rw-p b70c1000 00:00 0
>> b70c3000-b71f1000 r-xp 00000000 fd:00 197869 /usr/lib/libhdf5-1.6.6.so.0.0.0
>> b71f1000-b71f2000 r--p 0012e000 fd:00 197869 /usr/lib/libhdf5-1.6.6.so.0.0.0
>> b71f2000-b71f4000 rw-p 0012f000 fd:00 197869 /usr/lib/libhdf5-1.6.6.so.0.0.0
>> b71f4000-b71f5000 rw-p b71f4000 00:00 0
>> b71f5000-b723a000 r-xp 00000000 fd:00 198197 /usr/lib/libjasper.so.1.0.0
>> b723a000-b723b000 r--p 00044000 fd:00 198197 /usr/lib/libjasper.so.1.0.0
>> b723b000-b723e000 rw-p 00045000 fd:00 198197 /usr/lib/libjasper.so.1.0.0
>> b723e000-b7244000 rw-p b723e000 00:00 0
>> b7244000-b7259000 r-xp 00000000 fd:00 98434 /lib/tls/i686/cmov/libpthread-2
>> .9.so
>> b7259000-b725a000 r--p 00014000 fd:00 98434 /lib/tls/i686/cmov/libpthread-2
>> .9.so
>> b725a000-b725b000 rw-p 00015000 fd:00 98434 /lib/tls/i686/cmov/libpthread-2
>> .9.so
>> b725b000-b725d000 rw-p b725b000 00:00 0
>> b725d000-b75e6000 r-xp 00000000 fd:00 198036 /usr/lib/libxerces-c.so.28.0
>> b75e6000-b75f4000 r--p 00388000 fd:00 198036 /usr/lib/libxerces-c.so.28.0
>> b75f4000-b7616000 rw-p 00396000 fd:00 198036 /usr/lib/libxerces-c.so.28.0
>> b7616000-b763a000 r-xp 00000000 fd:00 199031 /usr/lib/libexpat.so.1.5.2
>> b763a000-b763c000 r--p 00023000 fd:00 199031 /usr/lib/libexpat.so.1.5.2
>> b763c000-b763d000 rw-p 00025000 fd:00 199031 /usr/lib/libexpat.so.1.5.2
>> b763d000-b7648000 r-xp 00000000 fd:00 197050 /usr/lib/libodbcinst.so.1.0.0
>> b7648000-b7649000 r--p 0000a000 fd:00 197050 /usr/lib/libodbcinst.so.1.0.0
>> b7649000-b764a000 rw-p 0000b000 fd:00 197050 /usr/lib/libodbcinst.so.1.0.0
>> b764a000-b764b000 rw-p b764a000 00:00 0
>> b764b000-b76ad000 r-xp 00000000 fd:00 200524 /usr/lib/libodbc.so.1.0.0
>> b76ad000-b76ae000 r--p 00061000 fd:00 200524 /usr/lib/libodbc.so.1.0.0
>> b76ae000-b76b2000 rw-p 00062000 fd:00 200524 /usr/lib/libodbc.so.1.0.0
>> b76b2000-b772f000 r-xp 00000000 fd:00 198741 /usr/lib/libsqlite3.so.0.8.6
>> b772f000-b7730000 r--p 0007d000 fd:00 198741 /usr/lib/libsqlite3.so.0.8.6
>> b7730000-b7731000 rw-p 0007e000 fd:00 198741 /usr/lib/libsqlite3.so.0.8.6
>> b7731000-b7740000 r-xp 00000000 fd:00 197743 /usr/lib/libgeos_c.so.1.4.1
>> b7740000-b7741000 rw-p 0000e000 fd:00 197743 /usr/lib/libgeos_c.so.1.4.1
>> b7741000-b7c1f000 r-xp 00000000 fd:00 202927 /usr/lib/libgdal1.5.0.so.1.12.2
>> b7c1f000-b7c31000 r--p 004de000 fd:00 202927 /usr/lib/libgdal1.5.0.so.1.12.2
>> b7c31000-b7c71000 rw-p 004f0000 fd:00 202927 /usr/lib/libgdal1.5.0.so.1.12.2
>> b7c71000-b7cb4000 rw-p b7c71000 00:00 0
>> b7cb4000-b7ce5000 r-xp 00000000 fd:00 198848 /usr/lib/libproj.so.0.5.5
>> b7ce5000-b7ce7000 rw-p 00031000 fd:00 198848 /usr/lib/libproj.so.0.5.5
>> b7ce7000-b7ce8000 rw-p b7ce7000 00:00 0
>> b7ce8000-b7d3a000 r-xp 00000000 fd:00 197496 /usr/lib/libtiff.so.4.2.1
>> b7d3a000-b7d3c000 r--p 00052000 fd:00 197496 /usr/lib/libtiff.so.4.2.1
>> b7d3c000-b7d3d000 rw-p 00054000 fd:00 197496 /usr/lib/libtiff.so.4.2.1
>> b7d3d000-b7e27000 r-xp 00000000 fd:00 199062 /usr/lib/libX11.so.6.2.0
>> b7e27000-b7e28000 ---p 000ea000 fd:00 199062 /usr/lib/libX11.so.6.2.0
>> b7e28000-b7e29000 r--p 000ea000 fd:00 199062 /usr/lib/libX11.so.6.2.0
>> b7e29000-b7e2b000 rw-p 000eb000 fd:00 199062 /usr/lib/libX11.so.6.2.0
>> b7e2b000-b7e2c000 rw-p b7e2b000 00:00 0
>> b7e2c000-b7e3b000 r-xp 00000000 fd:00 197079 /usr/lib/libXpm.so.4.11.0
>> b7e3b000-b7e3c000 rw-p 0000f000 fd:00 197079 /usr/lib/libXpm.so.4.11.0
>> b7e3c000-b7e50000 r-xp 00000000 fd:00 49250 /lib/libz.so.1.2.3.3
>> b7e50000-b7e51000 r--p 00013000 fd:00 49250 /lib/libz.so.1.2.3.3
>> b7e51000-b7e52000 rw-p 00014000 fd:00 49250 /lib/libz.so.1.2.3.3
>> b7e52000-b7e76000 r-xp 00000000 fd:00 196618 /usr/lib/libpng12.so.0.27.0
>> b7e76000-b7e77000 r--p 00023000 fd:00 196618 /usr/lib/libpng12.so.0.27.0
>> b7e77000-b7e78000 rw-p 00024000 fd:00 196618 /usr/lib/libpng12.so.0.27.0
>> b7e78000-b7eea000 r-xp 00000000 fd:00 197766 /usr/lib/libfreetype.so.6.3.20
>> b7eea000-b7eee000 r--p 00071000 fd:00 197766 /usr/lib/libfreetype.so.6.3.20
>> b7eee000-b7eef000 rw-p 00075000 fd:00 197766 /usr/lib/libfreetype.so.6.3.20
>> b7eef000-b7ef0000 rw-p b7eef000 00:00 0
>> b7ef0000-b7f0f000 r-xp 00000000 fd:00 198194 /usr/lib/libjpeg.so.62.0.0
>> b7f0f000-b7f10000 rw-p 0001e000 fd:00 198194 /usr/lib/libjpeg.so.62.0.0
>> b7f10000-b7f2e000 r-xp 00000000 fd:00 197300 /usr/lib/libgd.so.2.0.0
>> b7f2e000-b7f2f000 r--p 0001d000 fd:00 197300 /usr/lib/libgd.so.2.0.0
>> b7f2f000-b7f4e000 rw-p 0001e000 fd:00 197300 /usr/lib/libgd.so.2.0.0
>> b7f4e000-b7f52000 rw-p b7f4e000 00:00 0
>> b7f5c000-b7f5e000 rw-p b7f5c000 00:00 0
>> b7f5e000-b7f7a000 r-xp 00000000 fd:00 49155 /lib/ld-2.9.so
>> b7f7a000-b7f7b000 r--p 0001b000 fd:00 49155 /lib/ld-2.9.so
>> b7f7b000-b7f7c000 rw-p 0001c000 fd:00 49155 /lib/ld-2.9.so
>> bf967000-bf97c000 rw-p bffeb000 00:00 0 [stack]
>> ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso]
>> Aborted
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
