[mapserver-users] Silverlight Interface for Mapserver
Pano Voudouris
pvoudouris at gaiocorp.com
Fri May 22 09:20:56 EDT 2009
Hi Anil,
I am not sure what you are after here. If you want to see examples on how to
use silverlight (either using c# or vb) a good place to start is:
http://silverlight.net/GetStarted/
Hope this helps?
Regards,
Pano
From: adhiman (via Nabble) [mailto:ml-user+226069-1989752231 at n2.nabble.com]
Sent: 21 May 2009 15:44
To: Pano Voudouris
Subject: Re: [mapserver-users] Silverlight Interface for Mapserver
I have seen your application. It sounds great. I need a bit of clarity on
this piece of application.
How can we use mapscript C# with silverlight. Please let me know:
Regards,
Anil Dhiman
Pano Voudouris wrote:
Hi all,
This is just for info in case anyone is interested and working with these
technologies. We have created a silverlight front-end to Mapserver using
mapscript c#. The "map serving" logic is based on the excellent "MapFlash
Viewer Framework demo" done by Paolo Corti
http://www.paolocorti.net/2006/10/26/mapflashviewer-framework and extended
to include more functionality. On the other hand in our case it now focuses
squarely on mapserver.
The app was developed to be run either as a standalone, low-cost "webGIS" or
as embedded 'map in app' in other web pages. (And yes - pages will need to
be of the .NET flavour...)
You can have a play at the demo at: http://193.92.131.105/slmapview
Note though that the actual data is in greek!However assuming you do not
have your browser set to Greek you should be able to see the rest of the app
in English.
Pano
_____
This email is a reply to your post @
http://n2.nabble.com/Silverlight-Interface-for-Mapserver-tp2791496p2951737.h
tml
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Silverlight-Interface-for-Mapserver-tp2791496p2957356.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090522/60b9a6d4/attachment.html
