[mapserver-users] Oracle Spatial and "styleitem auto"
Tamas Szekeres
szekerest at gmail.com
Fri May 22 18:30:26 EDT 2009
If you are using OGR to access the Oracle Spatial data source, you could
specify a valid OGR style string in the table by adding field with name:
'OGR_STYLE'.
In this case OGR will extract the feature style automatically when using the
STYLEITEM "AUTO" option with this OGR layer.
For more information about the OGR feature style strings see:
http://www.gdal.org/ogr/ogr_feature_style.html
You could use ogr2ogr to transfer the feature styles between various data
sources, see the document above.
Best regards,
Tamas
2009/5/22 Jelmer Baas <Baas at speerit.nl>
> Hello List,
> Are there any plans to create a way for MapServer to automaticly apply a
> certain style to data retrieved from Oracle Spatial? For example by
> specifying a style column in the mapfile which contains a MapInfo style
> description?
> With kind regards,
> Jelmer Baas
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090523/ee6f4f1c/attachment.html
