[mapserver-users] display map on aspx page
sunny74 sb.ray at hotmail.com
Sun May 24 03:03:06 EDT 2009
Jeff McKenna wrote:
> Luke Kateregga wrote:
>> Hello there,
>> Iam new to mapserver. I have installed mapserver plus the demo
>> applications - chameleon, p_mapper etc and they are all working fine.
>> The problem is I just cant load my own data. I've tried the  mapserver
>> generator in mapwindow, the qgis web plugin plus Amien in Arcmap but
>> still no success. I am currently following Web Mapping Illustrated By
>> Tyler Mitchell, working on his very first example of global.map,
>> global.html. When I click start map server, I get a page with a blank
>> portion, instead of the map itself. The gif however is created in the
>> ms_tmp folder. How do I get to display the map in the browser?
>> Can also anyone perhaps show me how I can import my own data into the
>> already made applications like Pmapper or fusion?
>> Thanks in advance
> Hello Luke,
> Welcome to the world of MapServer, I think you're going to love it.
> I think you should focus on your .map file first, and then worry about
> the applications later.  To start with, you could go through the
> MapServer workshop[1] that is given every year at the FOSS4G conference
> - in that you will have access to data and working mapfiles.  Also, test
> your mapfile using the shp2img commandline utility[2].  I would start
> with a small mapfile with only one layer, test it with shp2img, and once
> that single layer is showing in the resulting map image from that
> command, continue adding layers.
> That should get you going.  If you ever get totally frustrated, there
> are providers out here to help, like myself, offering direct support
> services, so keep that in mind.
> Anyway good luck and have fun.
> -jeff
> [1]
> http://www.gatewaygeomatics.com/dl/mapserver-workshop/ms101_ms4w_package.zip
> [2] http://www.mapserver.org/utilities/shp2img.html
> Jeff McKenna
> FOSS4G Consulting and Training Services
> Hi Jeff,
> Could u pls look into my problem and help solve it.
> I want to use openlayers with mapserver in ASP.NET 2.0/C# web application.
> I am looking for detailed guidance/ support in this regard and i am ready
> for alternative arrangement other than  this forum.
> If u r ready pls let me know.
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/display-map-on-aspx-page-tp2950436p2964334.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
