[mapserver-users] Oracle Spatial and "styleitem auto"
Tamas Szekeres szekerest at gmail.com
Sun May 24 16:34:13 EDT 2009
Yes, you should post this question to the gdal-dev list, hopefully Daniel
could comment it.
Best regards,
Tamas
2009/5/24 Jelmer Baas <Baas at speerit.nl>
>  Tamas,
> Thanks to your url I managed to get it working. The performance is way
> better than I hoped! The only thing that doesn't seem to work is linewidth
> for (poly)lines. The style
> PEN(w:8px,c:#FF6A00) still draws a 1 or 2 pixel line. I tried using cm,
> pt, etc, but that doesn't change anything.
> I don't have a style in my map file that overrides it, too (only a class
> with name and template).
> Any ideas? Or should I ask this question in a gdal/ogr list?
> Regards,
> Jelmer Baas
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* zaterdag 23 mei 2009 0:30
> *To:* Jelmer Baas
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Oracle Spatial and "styleitem auto"
> Hi,
> If you are using OGR to access the Oracle Spatial data source, you could
> specify a valid OGR style string in the table by adding field with name:
> 'OGR_STYLE'.
> In this case OGR will extract the feature style automatically when using
> the STYLEITEM "AUTO" option with this OGR layer.
> For more information about the OGR feature style strings see:
> http://www.gdal.org/ogr/ogr_feature_style.html
> You could use ogr2ogr to transfer the feature styles between various data
> sources, see the document above.
> Best regards,
> Tamas
> 2009/5/22 Jelmer Baas <Baas at speerit.nl>
>> Hello List,
>> Are there any plans to create a way for MapServer to automaticly apply a
>> certain style to data retrieved from Oracle Spatial? For example by
>> specifying a style column in the mapfile which contains a MapInfo style
>> description?
>> With kind regards,
>> Jelmer Baas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090524/8137a23a/attachment.html
