[mapserver-users] P.MAPPER-ERROR
Gonzalo Lionel Rodriguez
gonzalo at sepp0.com.ar
Sun May 24 16:34:24 EDT 2009
Hi everyone... o customize my own .map and i have this error in pm_debug.log:
[24-May-2009 15:30:03] P.MAPPER debug info
P.MAPPER-ERROR: Layer/Group 'Pampa' not existing. Check
'/config/config.ini' file definition for section 'defGroups'.
P.MAPPER-ERROR: Layer/Group 'MontedeLlanurasyMesetas' not existing.
Check '/config/config.ini' file definition for section 'defGroups'.
P.MAPPER-ERROR: Layer/Group 'EstepaPatagónica' not existing. Check
I dont know whats wrong, any idea?
Here is my config.ini
; LAYERS/GROUPS DEFINED MANUALLY
; ALL groups displayed in TOC in this order
; - without definition, the order from map file will be taken.
; - separated with commas
; if INI setting "useCategories = 1" (see below),
; then define the categories in php_config.php
; === RECOMMENDED ===
;allGroups = Argentina, Hidrografia, Rutas, Departamentos, Presas
;allGroups = Imágenesdesatélite, RecursosNaturales, RecursosNaturales,
RecursosHídricos, Límitesadministrativos, Límites administrativos,
RecursosHídricos, RecursosHídricos, InfraestructuraVial,
Límitesadministrativos, RecursosNaturales, Altos, Puna, SelvaYungas,
ChacoSeco, ChacoHúmedo, SelvaParanense, EsterosdelIberá,
CamposyMalezales, DeltaeIslasdelParaná, Espinal, Pampa,
MontedeLlanurasyMesetas, EstepaPatagónica, BosquesPatagónicos,
IslasdelAtlánticoSur, MarArgentino, ParqueChaqueño, SelvaMisionera,
SelvaTucumanoBoliviana, BosqueAndinoPatagónico, Espinal, Monte,
EspejosdeAgua, Ríopermanente, Ríotransitorio, Rutanacional,
Rutaprovincial, Capitalprovincial, Cabeceradepartamental
RecursosHídricos, Límitesadministrativos, RecursosHídricos,
RecursosHídricos, InfraestructuraVial, Límitesadministrativos,
RecursosNaturales
; Default Groups (visible at start)
; defGroups = Argentina, Hidrografia, Rutas, Departamentos, Presas
;defGroups = Imágenes, de, satélite, Recursos, Hídricos, Límites,
administrativos, Límites, administrativos, Recursos, Hídricos,
Recursos, Hídricos, Infraestructura, Vial, Límites, administrativos,
Recursos, Naturales
defGroups = Imágenesdesatélite, RecursosNaturales, RecursosNaturales,
Rutaprovincial, Capitalprovincial, Cabeceradepartamental, Límites,
administrativos, Altos, Puna, SelvaYungas, ChacoSeco, ChacoHúmedo,
SelvaParanense, EsterosdelIberá, CamposyMalezales,
DeltaeIslasdelParaná, Espinal, Pampa, MontedeLlanurasyMesetas,
EstepaPatagónica, BosquesPatagónicos, IslasdelAtlánticoSur,
MarArgentino, ParqueChaqueño, SelvaMisionera, SelvaTucumanoBoliviana,
BosqueAndinoPatagónico, Espinal, Monte, EspejosdeAgua, Ríopermanente,
Ríotransitorio, Rutanacional, Rutaprovincial, Capitalprovincial,
; Groups/Layers that shall be mutually disabled
; if one is clicked, the other ones will be disabled
;mutualDisableList = dem, jpl_wms_global_mosaic, corine
; Groups/Layers list where to use auto_identify(tooltip) function
; === OPTIONAL ===
;autoIdentifyGroups = countries, cities
; Automatically refresh map when selection of
; layers/grouops has changed in TOC
layerAutoRefresh = 1
And a part of my .map
MAP
NAME "capas geográficas básicas"
STATUS ON
EXTENT 1821800 3700000 5728200 7600000
SIZE 500 500
SHAPEPATH "/home/orsep/public_html/gis2/capas_geograficas_basicas/data"
SYMBOLSET "/home/orsep/public_html/gis2/capas_geograficas_basicas/etc/symbols.sym"
FONTSET "/home/orsep/public_html/gis2/capas_geograficas_basicas/etc/fonts.txt"
IMAGETYPE png
IMAGECOLOR 255 255 255
UNITS METERS
WEB
IMAGEPATH '/home/orsep/public_html/gis2/tmp/'
IMAGEURL '/gis2/tmp/'
END
REFERENCE
STATUS ON
IMAGE "images/argentina.jpg"
SIZE 80 132
EXTENT 2.75e+06 3.75e+06 5.1e+06 7.65e+06
COLOR -1 -1 -1
OUTLINECOLOR 255 153 0
MINBOXSIZE 3
MAXBOXSIZE 0
MARKER 0
MARKERSIZE 0
END
QUERYMAP
STATUS ON
SIZE -1 -1
COLOR 255 222 73
STYLE SELECTED
END
LEGEND
STATUS ON
TRANSPARENT ON
INTERLACE OFF
POSITION LL
KEYSIZE 15 9
KEYSPACING 5 0
TEMPLATE "/var/www/medioambiente/maplab/projects/gmf_apps/sian/legend_template.html"
LABEL
TYPE TRUETYPE
FONT "fritqat"
SIZE 6
MINSIZE 4
MAXSIZE 256
OFFSET 0 0
ANGLE 0.000000
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
ANTIALIAS TRUE
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 205 205 205
OUTLINECOLOR 100 100 100
BACKGROUNDCOLOR 255 170 0
UNITS KILOMETERS
INTERVALS 5
SIZE 220 4
STYLE 0
POSITION LC
LABEL
TYPE BITMAP
SIZE TINY
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT OFF
END
LAYER
NAME "LANDSAT"
GROUP "Imágenesdesatélite"
STATUS OFF
DATA "mosaico_arg_georef.tif"
# ok
TYPE RASTER
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
CLASS
#NAME " "
END
# CLASS
END
LAYER
NAME "Ecoregiones"
GROUP "RecursosNaturales"
STATUS ON
DATA "eco_reg_gk3"
TYPE POLYGON
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 0
OFFSITE 0 0 0
TEMPLATE "../maplab/htdocs/mapbrowser/template/template.map"
CLASS
NAME "Altos"
EXPRESSION ('[Ecorreg]' = 'Altos Andes')
STYLE
SYMBOL 0
COLOR 249 239 236
OUTLINECOLOR 255 255 255
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
CLASS
NAME "Puna"
EXPRESSION ('[Ecorreg]' = 'Puna')
STYLE
SYMBOL 0
COLOR 215 217 181
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
CLASS
NAME "M"
EXPRESSION ('[Ecorreg]' = 'Monte de Sierras y Bolsones')
STYLE
SYMBOL 0
COLOR 185 213 187
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
CLASS
NAME "SelvaYungas"
EXPRESSION ('[Ecorreg]' = 'Selva de las Yungas')
STYLE
SYMBOL 0
COLOR 237 239 228
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
CLASS
NAME "ChacoSeco"
EXPRESSION ('[Ecorreg]' = 'Chaco Seco')
STYLE
SYMBOL 0
COLOR 230 226 208
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
CLASS
NAME "ChacoHúmedo"
EXPRESSION ('[Ecorreg]' = 'Chaco Húmedo')
STYLE
SYMBOL 0
COLOR 248 240 231
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
CLASS
NAME "SelvaParanense"
EXPRESSION ('[Ecorreg]' = 'Selva Paranense')
STYLE
SYMBOL 0
COLOR 191 230 192
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
Kind regards
