[mapserver-users] Oracle Spatial and "styleitem auto"
Jelmer Baas Baas at speerit.nl
Mon May 25 10:23:19 EDT 2009
> MapServer needs a circle symbol to use as a brush to render
> thick lines.
> Try defining a symbol called "default-circle" in your symbolset, this
> symbol should be used to render thick lines.
> This is explained in the paragraph on "Line Thickness" at:
> http://mapserver.org/input/vector/ogr.html#mapping-of-ogr-styl
> e-info-to-the-mapserver-class-members
> A new WIDTH parameter has been added to the style object in recent
> releases that removes the need for the circular brush, but that's not
> supported yet by the STYLEITEM code... I'll need to add it.
Daniel,
Thank you, this works like a charm.
Regards,
Jelmer Baas
