[mapserver-users] Transparent PNG
Balázs Bámer
bamerbalazs at gmail.com
Tue May 26 05:29:47 EDT 2009
Hi All,
I use Mapserver 5.2.2 and would like to produce transparent PNGs such
that if there is a red polygon, its red fill and stroke would be for
example 50% transparent. I need this to let an other layer's polygon
appear at the same location. I tried the following way:
CLASS
NAME "Fekves"
STYLE
COLOR 27 158 119
OUTLINECOLOR 27 158 119
OPACITY 50
END
END
in the layer descriptions
and a format part in the MAP section:
OUTPUTFORMAT
NAME png32
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
and a corresponding line
IMAGETYPE png32
but not succeeded, everything is totally opaque. Mapserver is compiled using
./configure --with-oci \
--with-oraclespatial=/usr/local/instantclient_11_1 \
--with-proj --with-threads --with-gdal --with-ogr \
--with-jpeg --with-png=/usr/lib --with-php=/usr/include/php5
--with-wmsclient --with-wfsclient
I tried adding the option --with-experimental-png but it missed some
libraries I coudln't find.
I know it is possible to generate such output using Geoserver, but now
I need to use Mapserver.
What is the solution?
Thank you in advance, best regards: Balázs Bámer
