[mapserver-users] Problems getting a JP2 or TIFF raster layer drawen
Pano Voudouris pvoudouris at gaiocorp.com
Wed May 27 04:22:42 EDT 2009
How are you trying to display the mapfile? Just by using cgi-bin? E.g.
.../mapserv.exe?map=<path_to_mapfile>&mode=map ...etc?
I have found- and I am not sure if this is a bug or not that the mode=map
ignores any raster layers. If you use mode=browse or mapscript it works
w/out a problem. Anyone? Is this a known issue??
Pano
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Michael Da
Silva Pereira
Sent: 27 May 2009 10:15
To: David Martinez Morata
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Problems getting a JP2 or TIFF raster layer
drawen
I've tried by even disabling my shapefile all together and only trying
to display the raster and still no luck.
Thanks
2009/5/27 David Martinez Morata <damarmo at gmail.com>:
> Hello.
> Try to change the palcement of your layers and configure your shape  with
> TRANSPARENT TRUE varible..
> Something like
> LAYER
>        NAME '2627D'
>        TYPE RASTER
>        STATUS ON
>        DATA "/var/www/ms-tmp/2627D.JP2"
> END
> LAYER
>        NAME vereenigingroads
>        STATUS ON
>        DATA vereenigingroads/
> vereenigingroads.shp
>        TYPE LINE
> TRANSPARENT TRUE
>        CLASS
>                NAME 'the world'
>                COLOR 0 0 0
>        END
> END
> 2009/5/27 Michael Da Silva Pereira
<michael.dasilvapereira at iburstafrica.com>
>> Hi,
>> I am having a problem displaying a JP2 / TIFF image in mapserver, it
>> draws my shape files. However I can not get it to draw my RASTER layer
>> Any Suggestions?
>> MAP
>>        SIZE 1300 600
>>        DEBUG 5
>>        EXTENT 23.5 -34 23.6 -25
>>        IMAGECOLOR 180 180 250
>>        UNITS DD
>>        SCALEBAR
>>                STATUS EMBED
>>                UNITS KILOMETERS
>>                INTERVALS 3
>>                TRANSPARENT TRUE
>>                OUTLINECOLOR 0 0 0
>>        END
>> LEGEND
>>        STATUS EMBED
>>        POSITION LR
>>        TRANSPARENT TRUE
>> END
>> WEB
>>        TEMPLATE global.html
>>        IMAGEPATH "/var/www/ms-tmp/"
>>        IMAGEURL "/ms-tmp/"
>> END
>> LAYER
>>        STATUS ON
>>        DATA vereenigingroads/vereenigingroads.shp
>>        TYPE LINE
>>        CLASS
>>                NAME 'the world'
>>                COLOR 0 0 0
>>        END
>> END
>> LAYER
>>        NAME '2627D'
>>        TYPE RASTER
>>        STATUS ON
>> END
>> END
>> root at michael-laptop:/var/www/ms-tmp# /usr/lib/cgi-bin/mapserv -v
>> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE
>> [Wed May 27 08:47:04 2009].804606 msLoadMap(): 0.009s
>> [Wed May 27 08:47:04 2009].845677 msDrawMap(): Layer 0
>> (vereenigingroads), 0.039s
>> [Wed May 27 08:47:04 2009].845729 msDrawRasterLayerLow(2627D): entering.
>> [Wed May 27 08:47:06 2009].130721 msDrawMap(): Layer 1 (2627D), 1.285s
>> [Wed May 27 08:47:06 2009].131031 msDrawMap(): Drawing Label Cache,
0.000s
>> [Wed May 27 08:47:06 2009].131063 msDrawMap() total time: 1.326s
>> [Wed May 27 08:47:06 2009].163796 msSaveImage() total time: 0.033s
>> [Wed May 27 08:47:06 2009].163926 msFreeMap(): freeing map at 0x91168b8.
>> [Wed May 27 08:47:06 2009].163974 freeLayer(): freeing layer at
0x911d508.
>> [Wed May 27 08:47:06 2009].163995 freeLayer(): freeing layer at
0x911e1d0.
>> [Wed May 27 08:47:06 2009].164011 freeLayer(): freeing layer at
0x9246188.
>> [Wed May 27 08:47:06 2009].164025 freeLayer(): freeing layer at
0x92fea48.
>> [Wed May 27 08:47:06 2009].164045 shp2img total time: 1.369s
>> root at michael-laptop:/var/www/ms-tmp# du -hs 2627D.JP2
>> 129M    2627D.JP2
>> Regards,
>> Michael da Silva Pereira
>> Mobile: +27 84 245 2376
>> Office: +27 11 251 2036
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Martinez Morata David
> Thinking GIS
Regards,
