[mapserver-users] Problems getting a JP2 or TIFF raster layer drawen
Michael Da Silva Pereira michael.dasilvapereira at iburstafrica.com
Wed May 27 04:46:25 EDT 2009
I am trying to display from browser using browse mode,
/home/michael/mapserver-5.4.0/shp2img -m global.map -o test.png -all_debug 1000
2009/5/27 Pano Voudouris <pvoudouris at gaiocorp.com>:
> How are you trying to display the mapfile? Just by using cgi-bin? E.g.
> .../mapserv.exe?map=<path_to_mapfile>&mode=map ...etc?
> I have found- and I am not sure if this is a bug or not that the mode=map
> ignores any raster layers. If you use mode=browse or mapscript it works
> w/out a problem. Anyone? Is this a known issue??
> Pano
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Michael Da
> Silva Pereira
> Sent: 27 May 2009 10:15
> To: David Martinez Morata
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Problems getting a JP2 or TIFF raster layer
> drawen
> Hi,
> I've tried by even disabling my shapefile all together and only trying
> to display the raster and still no luck.
> Thanks
> 2009/5/27 David Martinez Morata <damarmo at gmail.com>:
>> Hello.
>> Try to change the palcement of your layers and configure your shape  with
>> TRANSPARENT TRUE varible..
>> Something like
>> LAYER
>>        NAME '2627D'
>>        TYPE RASTER
>>        STATUS ON
>>        DATA "/var/www/ms-tmp/2627D.JP2"
>> END
>> LAYER
>>        NAME vereenigingroads
>>        STATUS ON
>>        DATA vereenigingroads/
>> vereenigingroads.shp
>>        TYPE LINE
>> TRANSPARENT TRUE
>>        CLASS
>>                NAME 'the world'
>>                COLOR 0 0 0
>>        END
>> END
>> 2009/5/27 Michael Da Silva Pereira
> <michael.dasilvapereira at iburstafrica.com>
>>> Hi,
>>> I am having a problem displaying a JP2 / TIFF image in mapserver, it
>>> draws my shape files. However I can not get it to draw my RASTER layer
>>> Any Suggestions?
>>> MAP
>>>        SIZE 1300 600
>>>        DEBUG 5
>>>        EXTENT 23.5 -34 23.6 -25
>>>        IMAGECOLOR 180 180 250
>>>        UNITS DD
>>>        SCALEBAR
>>>                STATUS EMBED
>>>                UNITS KILOMETERS
>>>                INTERVALS 3
>>>                TRANSPARENT TRUE
>>>                OUTLINECOLOR 0 0 0
>>>        END
>>> LEGEND
>>>        STATUS EMBED
>>>        POSITION LR
>>>        TRANSPARENT TRUE
>>> END
>>> WEB
>>>        TEMPLATE global.html
>>>        IMAGEPATH "/var/www/ms-tmp/"
>>>        IMAGEURL "/ms-tmp/"
>>> END
>>> LAYER
>>>        STATUS ON
>>>        DATA vereenigingroads/vereenigingroads.shp
>>>        TYPE LINE
>>>        CLASS
>>>                NAME 'the world'
>>>                COLOR 0 0 0
>>>        END
>>> END
>>> LAYER
>>>        NAME '2627D'
>>>        TYPE RASTER
>>>        STATUS ON
>>> END
>>> END
>>> root at michael-laptop:/var/www/ms-tmp# /usr/lib/cgi-bin/mapserv -v
>>> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
>>> SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE
>>> [Wed May 27 08:47:04 2009].804606 msLoadMap(): 0.009s
>>> [Wed May 27 08:47:04 2009].845677 msDrawMap(): Layer 0
>>> (vereenigingroads), 0.039s
>>> [Wed May 27 08:47:04 2009].845729 msDrawRasterLayerLow(2627D): entering.
>>> [Wed May 27 08:47:06 2009].130721 msDrawMap(): Layer 1 (2627D), 1.285s
>>> [Wed May 27 08:47:06 2009].131031 msDrawMap(): Drawing Label Cache,
> 0.000s
>>> [Wed May 27 08:47:06 2009].131063 msDrawMap() total time: 1.326s
>>> [Wed May 27 08:47:06 2009].163796 msSaveImage() total time: 0.033s
>>> [Wed May 27 08:47:06 2009].163926 msFreeMap(): freeing map at 0x91168b8.
>>> [Wed May 27 08:47:06 2009].163974 freeLayer(): freeing layer at
> 0x911d508.
>>> [Wed May 27 08:47:06 2009].163995 freeLayer(): freeing layer at
> 0x911e1d0.
>>> [Wed May 27 08:47:06 2009].164011 freeLayer(): freeing layer at
> 0x9246188.
>>> [Wed May 27 08:47:06 2009].164025 freeLayer(): freeing layer at
> 0x92fea48.
>>> [Wed May 27 08:47:06 2009].164045 shp2img total time: 1.369s
>>> root at michael-laptop:/var/www/ms-tmp# du -hs 2627D.JP2
>>> 129M    2627D.JP2
>>> Regards,
>>> Michael da Silva Pereira
>>> Mobile: +27 84 245 2376
>>> Office: +27 11 251 2036
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Martinez Morata David
>> Thinking GIS
> Regards,
Regards,
