[mapserver-users] Attribute based symbol
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed May 27 14:26:47 EDT 2009
You can bind a style symbol to an attribute. The value needs to be the name of a
system already loaded by MapServer or the name of a local image. You cannot
reference a image url.
Steve
>>> On 5/27/2009 at 12:26 PM, in message
<a3cc80ca0905271026p141e3f92mf817e0e596f74ec at mail.gmail.com>, Adam Eskreis
<aeskreis at gmail.com> wrote:
> I am trying to create a layer that has a symbol, however, I want the symbol
> for each geometry to be based on a field from the database. For instance, I
> am trying to make a layer that would look something like this:
> LAYER
> GROUP symbol_layer
> TYPE point
> STATUS on
> CONNECTIONTYPE postgis
> CONNECTION "<connection string>"
> DATA "the_geom from (SELECT the_geom, symbol_img_url from foo) as foo
> using unique id using SRID=-1"
> CLASS
> STYLE
> SYMBOL "[symbol_img_url]"
> END
> END
> END
> Is something like this possible? If not, what part of the source would I
> have to edit in order to make it possible?
> Thank you
> -Adam
