[mapserver-users] [RESOLVED:] Mapserver/PostGIS map file problem
(double quotes in layer 'DATA' element)
Peter Willis
peterw at borstad.com
Wed May 27 19:26:17 EDT 2009
After a bit of experimentation I have discovered that
using single quotes, to enclose the element value, allows
double quotes to be used in the query.
ie:
DATA 'the_geom from (select oid,gid, the_geom,
"Area","Perimeter","PixelValue" FROM global_Land_poly WHERE
"PixelValue"=1 ) AS FOO using SRID=4326'
Thanks to all,
Peter
Peter Willis wrote:
> I tried that. I get the following error:
> loadLayer(): Unknown identifier. Parsing error near (Area):(line 30)
> Mapserver doesn't appear to like the additional formatting.
> Do I need to recompile with system regex I wonder....?
> Peter
> Adam Eskreis wrote:
>> You could try regex
>> \"Area\"
>> -Adam
>> On Wed, May 27, 2009 at 6:48 PM, Peter Willis <peterw at borstad.com
>> <mailto:peterw at borstad.com>> wrote:
>> Hello,
>> I am having a problem serving a PostGIS layer via mapserver
>> as WFS.
>> The problem arises from the generation/use of column names
>> in PostgreSQL that require double quotes.
>> ie:
>> SELECT oid,gid, the_geom, "Area","Perimeter","PixelValue" FROM
>> global_Land_poly WHERE "PixelValue"=1;
>> In the map file the 'DATA' member of the PostGIS layer is defined as:
>> DATA "the_geom from (select oid,gid, the_geom,
>> Area,Perimeter,PixelValue FROM global_Land_poly WHERE PixelValue=1 )
>> AS FOO using SRID=4326"
>> <ERR>Mapserver relays a PostGIS error from PostgreSQL:
>> 'ERROR: column "area" does not exist...</ERR>
>> This is because the column name is actually "Area"
>> and requires quotes.
>> How do I define double quotes in my PostGIS query
>> within the 'DATA' element of my mapfile layer?
>> Thanks for any enlightenment,
>> Peter
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Peter Willis
Remote Sensing Analyst, Programmer, Electronics Technician
ASL Borstad Remote Sensing Inc.
1986 Mills Road
Sidney, British Columbia, Canada V8L5Y3
Tel: 250-656-0177 extension 135
