[mapserver-users] SV: Clipping out unprojectable area?
paalkr
pal.kristensen at statkart.no
Thu May 28 09:38:08 EDT 2009
Hi!
Does anyone have a clue regarding what I have to do, to sort out this issue?
Regards,
Pål Kristensen
paalkr wrote:
> Hi, thanks for the help!
> I tried your suggestion, but I didn't manage to get it to work correctly,
> this is what I did:
> Entered the following DATA statement:
> DATA "geometri from ( select geometri, * from general.country where
> ST_Intersection(geometri,GeomFromText('POLYGON((12 0,18 0,18 84,12 84,12
> 0))',4326)) ) AS country USING UNIQUE ogc_fid USING SRID=4326"
> but I then got the following error in the MapServer logfile:
> [Mon May 25 14:03:08 2009].185400 msPostGISLayerWhichShapes query: select
> encode(AsBinary(force_collection(force_2d("geometri")),'NDR'),'base64') as
> geom,"ogc_fid" from ( select geometri, * from general.country where
> 0))',4326)) ) AS country where geometri &&
> GeomFromText('POLYGON((-5.89995617157446
> 59.7658748898858,-5.89995617157446 75.1604740311875,44.7675433183202
> 75.1604740311875,44.7675433183202 59.7658748898858,-5.89995617157446
> 59.7658748898858))',4326)
> [Mon May 25 14:03:08 2009].187786 msPostGISLayerWhichShapes query status:
> 7
> [Mon May 25 14:03:08 2009].187807 msPostGISLayerWhichShapes(): Query
> error. Error (ERROR: argument of WHERE must be type boolean, not type
> geometry
> Anyone that can help with this?
> Regards,
> Pål Kristensen
> Espen.Messel wrote:
>> Hi.
>> You could try something like this:
>> 0))',4326)) ) AS FOO USING UNIQUE ogc_fid USING SRID=4326"
>> It's not very nice, but it works.
>> Regards,
>> Espen
>> Espen Messel
>>> -----Opprinnelig melding-----
>>> Fra: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] På vegne av paalkr
>>> Sendt: 12. mai 2009 16:19
>>> Til: mapserver-users at lists.osgeo.org
>>> Emne: Re: [mapserver-users] Clipping out unprojectable area?
>>> Hi!
>>> I'm trying to achieve the same thing, but I need some hints
>>> on how to incorporate the spatial filter in the DATA
>>> statement. This is a snippet from my mapfile
>>> DATA "geometri from general.country USING UNIQUE
>>> and this is the spatial filter i try to apply
>>> 0,18 84,12
>>> 84,12 0))',4326))
>>> but I don't manage build the right the DATA statement!
>>> Can someone please help with the DATA statement?
>>> Regards,
>>> Pål Kristensen
>>> Gregor at HostGIS wrote:
>>> > With some SQL know-how I did get the EPSG database merged
>>> with our own
>>> > spatial_ref_sys table (it has other mods for our uses, so this was
>>> > trivial) and our program generating
>>> ST_Intersection(the_geom) statements.
>>> > This does work as expected, which is great. Thanks for
>>> another simple
>>> > and elegant solution, Christopher.
>>> > Now to cope with some of our data having self-intersecting polygons
>>> > which break such operators...
>>> > Gregor Mosheh / Greg Allensworth BS, A+, Network+,
>>> Security+, Server+
>>> > System Administrator, Lead Programmer
>>> > HostGIS development & hosting services, http://www.HostGIS.com/
>>> > "Remember that no one cares if you can back up,
>>> > only if you can restore." - AMANDA
>>> > _______________________________________________
>>> > mapserver-users mailing list
>>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Regards,
>>> Pål Kristensen
>>> View this message in context:
>>> http://n2.nabble.com/Clipping-out-unprojectable-area--tp229984
>> 7p2869427.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
Regards,
Pål Kristensen
View this message in context: http://n2.nabble.com/Clipping-out-unprojectable-area--tp2299847p2987697.html
