[mapserver-users] Mapserver layer + Openlayers = Random pink
tiles...
Paul james
pauljame at gmail.com
Thu May 28 11:05:16 EDT 2009
Hello guys...
I know It is a Openlayer question, but maybe someone here can help-me...
I did a simple sample to show my problem... My layer sometimes is 100%
showed, but when I zoom, several pink layers appears... Its absolute
RANDOM...
--> If I click right on the image, and get the image URL and PASTE on
browser, I CAN SEE THE IMAGE... So It was created fine...
Help? I´m getting crazy ...
ps.: Using Windows XP + IIS
Code:
Javascript :
var map, layer;
function init() {
map = new OpenLayers.Map('map', {
numZoomLevels: 14,
units: "meters",
controls: [
new OpenLayers.Control.ZoomToMaxExtent(),
new OpenLayers.Control.PanZoomBar({ zoomWorldIcon: true
new OpenLayers.Control.LayerSwitcher({ 'ascending':
false }),
new OpenLayers.Control.MousePosition(),
new OpenLayers.Control.MouseDefaults(),
new OpenLayers.Control.KeyboardDefaults()
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 10;
layer = new OpenLayers.Layer.MapServer("Sample", "
http://localhost/cgi-bin/mapserv.exe", { map: "C:/Sample/Openlayer/Map.map",
layers: "Test" });
map.addLayer(layer);
map.zoomToMaxExtent();
Mapfile
MAP
EXTENT -79.7892 -34.2426 -24.9958 6.11775
FONTSET "Fonts\Fonts.txt"
IMAGECOLOR 230 254 254
IMAGETYPE png
SIZE 800 600
STATUS ON
UNITS dd
NAME "Test"
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
WEB
IMAGEPATH 'C:\map\temp'
IMAGEURL '/tmp/'
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
END
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS ON
STYLE hilite
END
REFERENCE
STATUS on
SIZE 221 150
MINBOXSIZE 5
MAXBOXSIZE 150
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
MARKERSIZE 8
END
LAYER
NAME Test
GROUP "Tests"
TYPE POLYGON
STATUS default
CONNECTIONTYPE POSTGIS
CONNECTION "user=xpassword=xdbname=x host=x port=5432"
DATA "the_geom from viwgeo_x USING UNIQUE oid USING SRID=-1"
CLASS
COLOR 255 0 255
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090528/a63a01b7/attachment-0001.html
