[mapserver-users] Mapserver layer + Openlayers = Random pink
tiles...
Paul james
pauljame at gmail.com
Thu May 28 12:59:12 EDT 2009
Hi Daniel!
I ckecked the IIS Log...
And I´m getting 403 to the pink tiles :
16:06:04 127.0.0.1 GET /cgi-bin/mapserv.exe 403
The IIS specification :
*403 *- Forbidden. IIS defines a number of different 403 errors that
indicate a more specific cause of the error:
*403.1* - Execute access forbidden.
*403.2* - Read access forbidden.
*403.3* - Write access forbidden.
*403.4* - SSL required.
*403.5* - SSL 128 required.
*403.6* - IP address rejected.
*403.7* - Client certificate required.
*403.8* - Site access denied.
*403.9* - Too many users.
*403.10* - Invalid configuration.
*403.11* - Password change.
*403.12* - Mapper denied access.
*403.13* - Client certificate revoked.
*403.14* - Directory listing denied.
*403.15* - Client Access Licenses exceeded.
*403.16* - Client certificate is untrusted or invalid.
*403.17* - Client certificate has expired or is not yet valid.
*403.18* - Cannot execute requested URL in the current application pool.
This error code is specific to IIS 6.0.
*403.19* - Cannot execute CGIs for the client in this application pool. This
*403.20* - Passport logon failed. This error code is specific to IIS 6.0.
Do you know how to "fix" that?
Thanks
On Thu, May 28, 2009 at 12:12 PM, Daniel Morissette <
dmorissette at mapgears.com> wrote:
> Paul james wrote:
>> --> If I click right on the image, and get the image URL and PASTE on
>> browser, I CAN SEE THE IMAGE... So It was created fine...
>> Help? I´m getting crazy ...
>> ps.: Using Windows XP + IIS
> Did you check your IIS logs? It could be that you have too many connections
> at the same time when OpenLayers loads the map and IIS rejects some of them.
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090528/8771183d/attachment.html
