[mapserver-users] Point lables and tiles
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu May 28 15:19:37 EDT 2009
Not within MapServer proper. The various tiling services use this
metatile approach so it does work. You'd need
an intermediary script to do the clipping for you.
Steve
>>> On 5/28/2009 at 8:36 AM, in message
<1243517779820-2987684.post at n2.nabble.com>,
paalkr <pal.kristensen at statkart.no> wrote:
> Hi!
> OK, are there any methods that could be used to let MapServer produce
a
> bigger image and then chop off excess area before sending the image
to the
> client? I think that this would be the easiest and most flexible
solution.
> Regards,
> Pål Kristensen
> Thomas Bonfort-2 wrote:
>> it doesn't put any labels in the 10 outermost pixels surrounding
the
>> generated image (as they are chopped off by tilecache's metabuffer)
>> thomas
>> www.camptocamp.com
>> +33 4 79 26 57 97
>> On Mon, May 25, 2009 at 16:45, paalkr <pal.kristensen at statkart.no>
wrote:
>>> Hi!
>>> Thanks for the hint! The problem is that I'm using GeoWebCache and
not
>>> tilecache :) Is the
>>> METADATA
>>> labelcache_map_edge_buffer "-10"
>>> END
>>> a MapServer keyword? What does it do exactly?
>>> Any other possible solutions?
>>> Regards,
>>> Pål Kristensen
http://lists.osgeo.org/pipermail/mapserver-users/2009-March/060214.html
>>>> regards,
>>>> thomas
>>>> www.camptocamp.com
>>>> +33 4 79 26 57 97
>>>> On Mon, May 25, 2009 at 15:00, paalkr
>>>> wrote:
>>>>> Hi!
>>>>> When creating tiles for my tilecache I have some issues regarding
point
>>>>> labels. Using the PROCESSING label_no_clip=true works for line
and
>>>>> polygon
>>>>> labels, but points has not area/size and will therefor newer be
present
>>>>> in
>>>>> two neighbouring tiles. The result are clipped labels because
only one
>>>>> tile
>>>>> will ever know about the presence of a point. If then the label
should
>>>>> have
>>>>> been rendered into the next tile, it will be clipped. Metatiles
>>>>> (requesting
>>>>> more than one tile at a time and splitting it up on the tile
server)
>>>>> helps,
>>>>> but only a little, as the same problem will occur between
metatiles.
>>>>> A solution would be that MapServer rendered each tile (map) some
>>>>> percentage
>>>>> larger than requested, and then chops of the excess area before
>>>>> delivering
>>>>> the final map. A setting at the MAP level of the mapfile
controlling
>>>>> this
>>>>> "grow" mechanism would be great, defining the percentage the map
shall
>>>>> be
>>>>> extended before rendering.
>>>>> Second, is there any other way to solve the issue? Especially if
there
>>>>> are
>>>>> already features in MapServer that can be used.
>>>>> Regards,
>>>>> Pål Kristensen
>>>>> Regards,
>>>>> Pål Kristensen
>>>>> View this message in context:
http://n2.nabble.com/Point-lables-and-tiles-tp2969528p2969528.html
>>>>> Sent from the Mapserver - User mailing list archive at
Nabble.com.
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Regards,
>>> Pål Kristensen
>>> http://n2.nabble.com/Point-labels-and-tiles-tp2969528p2969950.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
> Regards,
> Pål Kristensen
> http://n2.nabble.com/Point-labels-and-tiles-tp2969528p2987684.html
